So the 2.6 is actually over cammed for its capacity?
Steve that IS 390 rwkw (and on stock injectors). Lol first posts states rwhp.
I am in Canberra but the car was tuned at Insight Motorsport. The Superlap Tilton Evo was there while my car was getting tuned. Thing is a weapon (obviously) and beautifully put together.
Scott is tuning the car eh...good stuff. When were you there? I was in there Friday...did you see the Rotorbishi?
Edited by DiRTgarage
  • Replies 48
Posted Images
Scott, his Dad, and Greg are great. Very professional outfit. They were all sharp despite having pulled incredible hours to get the Evo ready. Scott told me today that they were on the Evo until 6am on Saturday too but you can tell they live for it.
I was there on Wednesday and Thursday.
Did see the Rotorbishi, amazing peice of engineering. Couldn't stop crawling over / under it .
Im sorry 390rwkw with r34 n1's amd stock injectors, something isn't adding up here
thats because its hp
so you saw the Rotorbishi...but did you hear it?
OK for the record;
The car runs 600cc nismo inj and produced 390 rwhp as per the first post and as Paul has indentified.
As for my statement ...'Steve that IS 390 rwkw (and on stock injectors). Lol...' please note the Lol as it clearly can't be the case.
Didn't hear it but saw the size of the frigging exhaust. Got to push the thing in and out of the workshop a couple of times, was fun with that set up, never had a flyweight car feel like 1700 kg before. Unfortunately that was the extent of its rotorvation.
OK for the record;
so it only needed 3 rebuilds instead of 6 :cheers:
I'm still putting money on the turbos are getting to their efficiency...
The N1s are good on a stock RB26 at around 24PSi...
Now you're pushing 17PSi through...
So an absolute pressure of 31.7PSi...
Now add in the fact you're ingesting an extra 15% of that air, rather then it being a restriction...
So you're really pushing ~37PSi...
Take back off the 1 atmosphere...
You're pushing around 22/23PSi "comparison" wise...
But you have to think, at the same time, when you push 15% more air in, you're pushing MORE then 15% more air out... (Heat, expansion, yada yada yada) you're just pushing those poor turbos WAY past their efficiency range...
Get the maps out, and do the maths... Those turbos are out of their league!
A friend pushes his at 24PSi on a stock capacity 26... Makes 320AWKW... And it makes it up near 6500RPM...
You may "only" be making 300AWKW in yours... But you have to think, you're making it at a LOT lower RPM if you're running outta power at 6250... Which means, you're making more torque... So you're using more fuel, and air (Less restriction, same boost level, more air flow... :( ), at a lower RPM...
TURBOS ARE OUT OF EFFICIENCY... Logic says it...
i haven't tried to look at the maps yet.
the way i sse it is that boost pressure is broadly related to what speed the turbos are being turned at - whether it's an RB26 or RB30 sized pump moving the exhaust gas. so i think i should be able to get 23 or so psi out of them either way before seeing a big hike in inlet temps. the fact that the 30 will push 15% more air just means that it should get to the 23 psi level at lower engine rpm.
i don't expect / want them to make more than 430rwhp, but while not wishing to compare dynos i'm a fair bit shy of that with 370rwhp at 15psi, remembering that he didn't want to run it at 17 psi due to inlet temps. injectors are 660cc so i think they should cover my needs pretty well. the head has some minor porting.
there has got to be some inefficiency raising the air temps. i reinstalled the heat shields over the stock exh manifolds as the amount of heat rising onto the twin turbo pipe is fairly substantial. might be worthless but we'll see. i'll try and post a dyno chart and also temp data.
you will not be loosing power if the temps are below 50 degrees.... ulness you arnt running a intercooler????? 20 odd psi and 300kw is the norm.. so thats not bad power from 1.2bar..
asked for the inlet temp data but didn't get it. def running an intercooler. still drops off at 6250 ish though, would like to retain legs through the gears so cams are prob a must anyway.
scott is still adamant that it's cams.
lined up to check pressure drop and temps on a local dyno.
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
