  • Replies 335
Its not a daily driven car.
It uses an R34 Bottom end apparently not sure exactly the difference between the two.
The head has had a little bit of work done to it. It has a Tomi exhaust cam, ecu etc.
Check out their www page it might have more info on there.
But at the end of the day.. WHO REALLY KNOWS!! :D
Mind you when the drive it on the drift days etc.. they do not run that 400rwkw+ through it as it. They run around the mid 300's.
The 446 was purely to win the dyno comp AFAIK, I was only using it as an example as if they made that sort of power on a dyno (not daily driver) it sort of says that a pull of just over 400hp shouldnt be a problem. Also (heresay) but I have been told numerous stories of guys running in excess of 300rwkw with stock rb25 bottom ends - reliably, mainly from Japan (I know, different fuel, etc)
And as Joel says, they were running mid 300 on the drift day, and as you saw Paul, it went around the track on the rev limiter (several times) and still managed to drive off under its own steam.
Just using example of bottom end strength to put GTSt's mind at ease:D :D
Hi Joel, our experience with RB25's has been 450 bhp, no more than 1.7 bar boost and very seldom over 7,500 rpm is pretty damn reliable on the standard internals. It really depends a lot on how good the tune is, how well controlled the temperatures are (oil, water and air) and what sort of condition the engine is in in the first place.
That's on pump premium unleaded. if you use a highly oxegenated fuel (Elf Turbomax or LMS for example) then an extra 100 bhp doesn't seem to cause any distress.
Hope that helps
I checked the JMS webiste, it states that 300rwkws odd is achieved using a Trust TD06-25G. For the life of me even allowing for racing fuels and more boost can i see that turbo making that power.
So just curious what turbo setup was capable of such power on an RB25 (a relatively stock one at that...the dyno chart looks a little different.)
Sydneykid, The MAP sensor on the wolf is in-built, so all you have to do is run a vaccum line from the plenum to the ECU, even people like me can do that. It is entirely plug'n'play, in the fact that it will work with the standard AFM (or aftermarket) but it does have the bebefit of being able to run MAP if you prefer. It comes with a 2bar map sensor, which can be upgraded to a 3bar MAP sensor if the need arises.
Yeh Buster i am familiar with your car and have no problem accepting that the TD06-25G is good for 300-330rwkws.
Sorry...
I checked the JMS webiste, it states that 300rwkws odd is achieved using a Trust TD06-25G. For the life of me even allowing for racing fuels and more boost can i see that turbo making that sort of power.
Should have read ... I checked the JMS webiste, it states that 300rwkws odd is achieved using a Trust TD06-25G. For the life of me even allowing for racing fuels and more boost can i see that turbo making the 446rwkws.
Thats what my previous post should have read... so i was not doubting the ability of a TD06-25G to make over 300rwkws, but 446rwkws. So just curious to know what turbo on an RB25 can make that sort of power?
Looking at the pic of the R33 on the dyno the turbo is definitly not a T88/T78, and a T67 is very similar to a TD06-25G...so doubt they would have changed it for one.
It doesnt look like a HKS3040 either or big Garret or Apexi turbo? So am i right in assuming the thing was still using a TD06-25G for the dyno run?
stop bickering about what does and doesnt make a good representation of power. If u do a mod to u r happy with the increase in power. then thats all there is to it. and if u want to crunch numbers all day long talk about something worth while. like GTR700 (Australia's fastest GTR!!!) At stage 1 (stock bottom end) it was pushing out about 450kW at all 4 wheels. when the engine got pulled apart for more work there was nothing wrong with it. the RB bottom end can take a huge amount of power without complaints.
If u want an accurate comparison of 2 cars put them on the same dyno one after the other. it aint gonna get much more accurate than that.
Hi GTS-t VSPEC, you posted "run a vacuum line from the plenum to the ECU". Since Steve-SST has declined to reply, can you let me know if you have experienced any delay in response with that length of vacuum hose? I have never been able to test it back to back and I am wondering if anyone else has.
I have tested 2 boost gauges side by side, one with a long vacuum hose and the other with almost none, and there is a noticeable difference in the transient readings. ie; the one with the short hose shows boost before the one with the longer hose. The absolute value is the same, it just takes more time for the air to pressurise the longer hose. This is particularly noticeable on rapid upchanges through the gearbox, say when doing a 1/4 run.
This is one of advantages quoted by Trust for their electronic boost gauges due to no hoses, that being, quicker response to changes. So I am not the only one who has seen this.
This does not show up during a dyno power run when testing a MAP sensor with long hoses as the dyno ramp rate is slow enough to enable the MAP sensor to keep up with boost rise. Plus you don't change gear on the dyno. So it would only show up when driving on the road or track with F&W lambda sensor and display connected. Since we run fuel enrichment under boost, if the MAP sensor is slow in responding you could have (in theory) boost without sufficient fuel until the MAP sensor caught up. I haven't tested it and I was wondering whether anyone else had.
Moving on, I keep seeing quotes saying that two of the big advantages of a Wolf is that you don't have to run AFM's and it is P&P. In my opinion the advantages are mutually exclusive ie; if you run AFM's then it is plug and play, but if you don't want to run AFM's then it is not P&P.
Hope that adds to the post
I think if you are not capable of installing the Wolf yourself then you shouldnt be intalling either the Wolf or the Power Fc in your car.
I still had the AFM installed on my old RB20 despite running a Microtech ECU, as its absence may have aroused ppls suspicions.
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
