hi all....
a question just came out of my head, and its been bugging me a lot...lolz, hence why im writing this thread, as we all know all skylines has a twin turbo's like all the GTR's and single turbo's like Gtst's and GTT's, from R32 to R34's...now since the R35 GTR came out from the market to the streets now in some part of the world, my question is, are they goin to make a Single Turbo R35 in the near future?? or am i just tripping??
to be honest, if they do make a production of R35 Single turbo or R35 GTT or Gtst, i would be the first person to purchase the bloody thing...
is this goin to happen or what>??
any suggestions on my idea??
Edited by myRB25DETT
https://www.sau.com.au/forums/topic/263116-r35-gtt-or-gtst-single-turbo-r35/
correct. We ALREADY have V35 & V36 non-turbo for the Skyline heritage with V6 engines...
... to which viewed isn't worthy to be a Skyline by some Skyline turbo inline six fanatics...
so basically the true SKYLINE IS DEAD.
We're only left with GTR which isn't Skyline, and V series Skylines that are not the Skylines as we knew them.
By that logic it also makes prince Skyline to C210\11 not a skyline.
Which means on this forum R32-R34 was only ever made :thumbsup:
Someone please close this thread :thanks:
Which means on this forum R32-R34 was only ever made :blink:
Someone please close this thread :D
What about the 30 and 31, i believe both came out in japan with a straight six turbo?
I think turbo or non-turbo is not the issue for purist. it's the engine configuration (inline 6) where the purist's heart lies.
ever since V35 uses VQ instead of inline 6 engines back in the RB era and before (L20E) it's kind of considered as not really a Skyline anymore, cos V configuration engine is a thing for the Z cars...
that said, the late R34 GTR they use in the JGTC have actually used the VQ30DETT engine during 2003-2004 season instead of the good old RB26DETT... and the 2008 R35 JGTC car actually uses the V8 engine
read more here
http://en.wikipedia.org/wiki/Nissan_VQ_engine
read more here
I dont think they are a real skyline purely because the V35 was based on the 350Z which was designed by the yanks.
That's a rubbish statement if I ever heard one, it's called evolution it's just some people are stuck in the dark ages.
KPGC10 - S20 - Straight 6 - non turbo
KPGC110 - S20 - Straight 6 - non turbo
DR30 - FJ20 - Straight 4 - turbo
The "RB" is dead...not the Skyline.
don't get me wrong I totally agree with you... but I was speaking from an hypothetical inline engine fanatics "skyline is dead".
in my heart, my V35 is still as much Skyline as it can get... although I would get 'bashed' by those fanatics that lives in the past... just because I have a VQ engine now
+1 to your evolution
Which means on this forum R32-R34 was only ever made :O
Actually the C210 came with an inline 6 turbo, the 2000GT-EX came with L20ET
KPGC10 - SR20 - Straight 6 - non turbo
KPGC110 - SR20 - Straight 6 - non turbo
S20
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
