Speaking of interior lights, I left one on, on Sunday. Flat battery this morning :)
Ended up buying a battery charger at Dick Snap in town, will be all good in the morning.
Although I wonder if it is possible to get to the toolkit in the boot with no power, as the boot release is electronic and I'm only aware of the rear seat release inside the boot? I had tools at home but it made me wonder...
https://www.sau.com.au/forums/topic/263148-v35-mods/page/2/#findComment-4513214
I've used a few globes from here http://www.ledsales.com.au/cart.php?target...;category_id=35
I'm going to be purchasing some of the LED light ribbon type to put in the sun visor mirrors as well as in the glove box.
I've done my doors and interior lights, I will post pics once I have them :P
https://www.sau.com.au/forums/topic/263148-v35-mods/page/2/#findComment-4515267
I've done my doors and interior lights, I will post pics once I have them ;)
oh cool i was thinking of doing the rest as well.... u wouldnt know wat type of bulbs are for the boot light, glove compartment and the ash tray light by any chance wud u? :P
https://www.sau.com.au/forums/topic/263148-v35-mods/page/2/#findComment-4515406
oh cool i was thinking of doing the rest as well.... u wouldnt know wat type of bulbs are for the boot light, glove compartment and the ash tray light by any chance wud u? :ermm:
The boot uses the wedge type globe, I put in a 6 LED kit, bright but doesn't seem to flood the boot enough. Will look to see if there is anything else that can. My last car I wired in Neon light :D
Glove box has a real small wedge (maybe, have to check again) type globe so I'm not sure if I'll find a LED type so I'm going to wire in one of those ribbon type kit from the site I posted up before.
Edited by Pulp
https://www.sau.com.au/forums/topic/263148-v35-mods/page/2/#findComment-4516648
  • 4 weeks later...
  • 9 months later...
Hi all,
Wondering if anyone could help... the lights under the doors don't work. ive replaced globes and still don;t work? everything else is fine...
is there a fuse for them? any help would be appreciated
thanks
Yeah check your fuses. Up and to the right of your accelerator are the fuses. Don't know which one but if everything else is working it might not be a fuse. Get and auto sparky in the end.
https://www.sau.com.au/forums/topic/263148-v35-mods/page/2/#findComment-5075007
thanks for the reply, yeah bit strange that the dome lights work at the door ones dont :D
i've checked all three fuse boxes all seem ok.
cheers
https://www.sau.com.au/forums/topic/263148-v35-mods/page/2/#findComment-5075278
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
