  • Replies 44
and i am almost certain its not the Mines GTR. This was built by Autostyle along the same lines to look and supposedly go like the real thing.
Wrong,
It is really a mines gtr, + more parts!
it was not built by autostyle
Edited by Angus Smart
This is correct, Autostyle built this car, it was not built by Mines in Japan... We were chatting to the Autostyle guys at Superlap they said they bought the engine and diffs from Mines.
Correct.
It was built by Mine's. 300k worth of building it
Here it is, really simple;
You, are, wrong.
If you knew the right people (which I highly doubt you do), i'd suggest you look at the receipts for the car.
There's a few. That one was Aussie delivered, so rare as all fu(k. Its at Autostyle for sale, one of their private cars.
oh yeah thats right
wonder how much that car is going for.......
thats one of the fastest cars in the world
0 - 100km = 2.6 sec
400m = 9.9 sec
apparently the Fastest ever street legal road car in the world.........
According to Ultima, its the "fastest supercar in the world"
www.autostyle.com.au for price
PERFORMANCE FIGURES FOR ULTIMA GTR720
0-60mph 2.6secs
0-100mph 5.3secs
30-70mph 1.8secs
0-100mph-0 9.4secs
100mph-0 3.6secs
Standing ¼ mile 9.9secs @143mph
Top Speed 231mph (gearing limited)
Skidpad (200ft) 1.176g
9's standard. Thats quick.
Auto style dont even own the Mines GTR , Stevo please confirm i am pretty sure this is on consignment because I KNOW THE ABOSOLUTE FULL HISTORY OF THIS CAR and everything you guys are saying is CRAP , i was looking at buying this car a while ago before i bought my first r34 , i can tell you this car is absolutely stunning but the way it runs DO NOT compare it to those you tube videos that you see of the Mines GTR ..
SIKS11 : please stop listening to what people tell you and read . autostyle does not build cars , they sell them ....
Black Widow : 300 k ? you serious man .
Angus Smart : sorry to break it to you but it is not the real deal .
0-60mph 2.6secs
0-100mph 5.3secs
30-70mph 1.8secs
0-100mph-0 9.4secs
100mph-0 3.6secs
WOW thats amazing!!
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
    • I've got MCA Blues on my V36 Skyline, and while I've managed to sort out issues with scrubbing/bottoming out by raising it a smidge and increasing the damping hardness, the rear end still sounds *super* noisy when driving on anything other than the flattest surface imaginable. It sounds like a small party of flamingos are just chatting away in the back, which makes me think there are several link points in the suspension contributing to the noise. Am I hearing dried out/worn bushings? None of it sounds like metal-on-metal, it sounds more like hard rubber squeaking on metal. It's been suggested that a bit of silicon spray on each bushing might quiet them down, but I'm not sure what material the current bushings are made of (probably factory, I imagine) and whether silicon spray will degrade that material.
    • The obvious answer here is get a ND2/3 RF with the Targa top. The red is nicer, too!
