Hello to Oz from London,
I have bought an R33 Spec II 1997 genuine (unmolested) car recently.
I would like to improve the car in a moderate and aesthetic way without ripping too much apart or
ending up with a messy looking engine bay :D
What benefit would I get from a stainless steel exhaust manifold or an aftermarket downpipe?
(The R33 has a catback 3'' aftermarket exhaust)
Or asked another way:
What modification would you recommend to improve performance (my target would be 300HP for the time being)?
Since the car is a daily commuter and grocery getter, drivability is paramount.
So I'm more interested in higher torque figures than a peaky power curve.
Cheers,
Andrew
Edited by Torques
https://www.sau.com.au/forums/topic/263291-r33gtst-useful-mods/
Gday Andrew,
Best bet would be to search on this section. There are literally hundreds of tips and pointers of what to do first. Things like you Budget and Availability of parts will be a big factor.
PLenty of guys here started with stock cars, like yours, and then slowly added parts (myself included).
The SEARCH button is your friend.
Good luck.
ending up with a messy looking engine bay :banana:
Cheers,
Andrew
Unsure wether your capable of getting someone to do nistune in london, or if any mechanics have the facilities to tune them. But computer would be an idea, if you can get your hands on a nistune or power FC even better. FMIC, Some form of upgraded intake or pod, injectors, airflow meter and boost controller. Theres lots of different ways you can go, although im far from being as mechanicly minded as others on this site, I was at the same stageas yourself not too long ago.
Theresa company over here that does rb25 Hi flows for around 900 Australian dollars and to my knowledge they ship overseas name of the company is hypergear.
I started with exhaust, FMIC, boost controller, pod, and computer.
I always found this a good basic guide:
http://nissanskyline.6te.net/tuning_GTS25T.htm
^^ that website is nothing more than dated information that was ripped from the very pages of SAU about 3-4 years ago.
Half the info that was taken, basically stolen, was wrong to begin with as the creator of that website had NO idea about performance.
Torques -
I suggest people use SAU only, and the FI Guide.
It's the reason it was created.
http://www.skylinesaustralia.com/forums/Fo...ick-t66556.html
Specifically the "what mods to do first" thread
http://www.skylinesaustralia.com/forums/fi...-co-t45218.html
Im locking this as its covered very well in the above threads... and of the day you've gotta decide what best fits based on your budget
Thanks
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
