Hi all
I have an R33 GTS-T with an RB25det and im going to put on a forward facing plenum
My question is can you run cooler piping from a front mount to a forward facing plenum without cutting a hole in the side of the engine bay??
I dont want to run the piping back under the cooler and use the original holes because the piping would end up being way too long,
or should I just not worry bout it and cut a hole and hope I dont ever get questioned about it?
I'm pretty sure there would not be enough room to run the piping under the chassis rail and then straight up, but i cant check on my car as my engine is out at the moment, so im guessing theres no way around cutting a hole.
Just wanted to see if it has been done before or if anybody had any ideas on how to achieve it?
cheers
Tave
https://www.sau.com.au/forums/topic/263621-cooler-piping/
Hi all
cheers
Tave
the shortest run is the best one.
CUT THE HOLE and buy a good intercooler not a cheep and nasty one.
https://www.sau.com.au/forums/topic/263621-cooler-piping/#findComment-4510391
yeah just cut it. we're all a bit precious when it first comes to it, but once the hole is there, you wont care.
paint any bare metal exposed on the hole to prevent rusting, and run a rubber thingy around the rim. what are they called? lol
use a good quality holesaw. i cut mine with a cheap cheap holesaw. doesnt work. it just grinds away the shape of a hole lol, but doesnt actually go through.
i ended up using a grinder and a dremel (15 bits later) to finish it up.
ahh fun times
https://www.sau.com.au/forums/topic/263621-cooler-piping/#findComment-4514431
who's done the forward facing plenum and then plumbed it through their existing hole? I dont want to have to change my washer bottle. I think Ive seen it done with a 90 degree bend straight off the throttle body to get down to and through the hole.
sorry to hijack but it is kinda a relevant question lol
https://www.sau.com.au/forums/topic/263621-cooler-piping/#findComment-4520013
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
