  • Replies 98
Posted Images
alright so i took these at the end of march but anyway...in case anyone else was there and wants some pics :(
whoop ass wednesday
edit: oh lots of fords because I was there for a ford thing.
Edited by mickey
Something went wrong tonight when i was shooting the moon (most of my shots didn't come out well at all as i was expecting)
Anyways this was the best shot i could do.. should try again while its still full moon.. but i cbf.. lol
AAAARGHHH !!!! went to do a shoot on my car and before I could get some good shots I found that every shot I took had green marks in the pic, anyone know what it is? It's one of my fav lens :P
Looks like some sort of green light nothing to do with the camera/lens in my opinion. I mean look down towards the right of the car theres a line of green light flashing onto it. im guessing the massive green spot in the middle of the image is coming from whatevers doing that green line aswell..
Wow some nice images in here :)
Cali great work with the bonnet pic..
nice panning shots there bnr...
Takz- Nice attempt with the digi cam!! I really wanna head back into the city one day to take some images with my new lens.. one day..
Zennon - nice concept i like it.. esp that first one.. But i wish the shutter speed was a tad slower.
anyways nice work slim as always!!
Not really photography, but here is my new marine setup im working one :blink:
- My 4*2*2 tank im going to be using.. much bigger than my current 70L tank :) heheh
- atm i got my corals etc in these huge drums.. waiting to get the tank drilled etc. .and im gonna make a new stand for it..
Anyways did you know Prank (owner of this site) is fully into marine setups!! who would have thought..
I spotted him on marine forums :)
thanks for the comment!
i can't decide whether to invest in a dslr cause i don't want to buy one then not end up using it! Well i have to try some night shots of my car and see how it turns out
that looks like a big project you got there!!! better take some nice photos once you get it running!
You will apprieacte photography more with the dslr.. But im biased :)
Heres a few pics taken with a dslr with stock kit lens.. So nothing special..
So same pictures of what you took - well similar:
http://i7.photobucket.com/albums/y276/sidd...MG_1295_PPc.jpg
http://i7.photobucket.com/albums/y276/sidd...MG_1278_PPc.jpg
http://i7.photobucket.com/albums/y276/sidd...MG_1309_PPc.jpg
http://i7.photobucket.com/albums/y276/siddr20/IMG_1301.jpg
http://i7.photobucket.com/albums/y276/siddr20/IMG_1324.jpg
http://i7.photobucket.com/albums/y276/sidd..._1293__PPns.jpg
hehe dont worry, i will be taking lots of photos when i get it up and running ;)
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
