Sau-vic Annual Great Ocean Road Cruise 04/04/09 Wrap Up
  • Replies 170
Great cruise. Best was through the twisties on the way back for Stage 1. Did Stage 2 go through that route as well?
Phatboy are you running stock clutch???
Nah mate nismo twinplate super coppermix. Why do you ask?
Any interference from cops or was it all smooth?
Nah, were a few in Apollo Bay and Geelong, but we were driving normally so it was fine.
Was definitely a cracking drive back through the mountains. I think I surprised a few with the power and prowess of the V35... I pity those who don't consider it a true Skyline. :(
Haha yeah, very surprised that boat could keep up. Was hearing radio chatter about it.
Yeah I was just cruising and hanging back and up ahead I saw all three R34s circling like vultures around this bus full of schoolgirls, I was like, let me in on the action!
Those girls were hilarious.
Hahahaha yea the bus was funny as, pity they didnt fancy ur passenger, lol. That was the bang bus, we should of stop and hope in.
hahahaha ye the girls got a little tpo excited lol they were running back and forth both side of the bus hahahaha
they especially got even more excited when ryan pulled out his pro like camera lol
Those chicks were the lols.
hahahaah yes we were vultures. almost like vultures that havent had a good feed of meat in awhile. :(
lol every time i saw you taking of at the lights or parking/reversing you were revving a fair bit so was just wondering :(
Lol maybe the clutch is worn or it's just my crap driving, but I find I have to rev it a bit to keep from stalling when I am in first or reverse. The friction point is quite sudden.
Loved playing with the white R34 GTR on the otways! Whats your user on here mate? I treid hard to keep up but your too quick hahaha.
Nick was being a girl and not keeping up lol
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
