I believe - for things like pins, bonnet scoups and so on... if they fall outside whats legal (and basically all of them do)
Then its an engineers, same as a non factory motor, brakes, suspension and so on that affect the car over general roadworthy...
By general i mean things like tyres, head/tail lights, seatbelts, "H" pattern on gearknob... all that pissy stuff in otherwords :)
So you would have filled the non-general. just because you put the factory bonnet on doesnt mean you aint going to swap it back later ;)
Same as the EPA has an apparent 3-strike rule... if you get 3 basic exhaust noise tests then they haul you in for a full EPA to check as obviously your swapping out mufflers and whatever else. Or they start taking pics and then your really fked.
  • Replies 68
hahah i got yelled at tonight for my S2 driving lights... aparently i'm not allowed to have them on
No you are not, if i could i would smash everyones with a hammer, they shit me.
do you need an engineers cert for changinging the brakes and suspension setup? so say new brakes, brake lines, LCA's shocks springs steering arms etc? also for a new rear axel and diff? or... yeah
Mr. Series 1 a bit jealous :D hehe its ok i've been there!
lol just kidding, anyways ive drven past many series 2's with thier driving lights on.. doesnt phase me... however the cop referred to them as "fog lights" and i thought fog lights were yellow, which i know are illegal when not foggy... but i never knew driving lights were illegal...
my s1 has fog lights, cant put them in tho coz they hit the intercooler.
http://www.vicroads.vic.gov.au/NR/rdonlyre...104/0/VSI20.pdf - January 2000, Page 7, Q57
Q57: When can i use the fog lamps on my car
A: There is no restriction on the use of front fog lamps. However the lamps must be correctly aimed as fog lamps so as not to dazzle other road users. Rear fog lamps may only be lit in abnormal weather conditions
Found that little bit of information interesting, however there may have been a new rule put in since then. If anyone has it in writing would be good.
Those rear lights are f**king blinding too, i use to do a run to warrnambool and back every night, one night i was following a chick in an excel and every time she put her high beams on she would put on her fog lights, no need for them but she did it every time and the rear light would light up the cab of the truck, in the end every time she put on her fog lights i would put my high beams on, did it all the way from colac to the next major town which i cant remember the name of, probably a good 50 k's.
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
