hey guys,
mate wants to make is S1 r33 go quicker. Just wondering wat u guys think he should do to get best results. wanting to spend around 3k, already has EBC and cat back zorst. also is it worth getting second hand parts for cheaper or just buy new.
thanks Jack
Complete the Exhaust ( Dump pipe + front pipe)
FMIC KIT
Cold Air Intake System (Airfilter + box etc)
Up the boost (12psi MAX)
Piggy Back ECU (safc) Or else full ecu + tune
should net you somewhere in the 250rwhp + region
edit: nothing wrong with buying second hand aslong as you check it out and condition is ok. NOTE: buy brand new air filter (unless it can be clean)
Edited by [Michael]
https://www.sau.com.au/forums/topic/264579-modifying-r33/#findComment-4523135
you will go faster if u use the search button. read the forced induction turbo upgrade dyno figures to see what mods most people do for what power.
But to make a car faster good tyres, LSD is a must. brakes should also be good to stop faster if u get to faster speed easier.
https://www.sau.com.au/forums/topic/264579-modifying-r33/#findComment-4523575
Sorry for interupting your thread, but I´m also making plans how to make my R33 GTS-T go faster at the moment, and came to the conclusion that the original turbo is crap. Is there any companies near the Perth area that rebuilds turbos and could maybe fit some other nice internals?
https://www.sau.com.au/forums/topic/264579-modifying-r33/#findComment-4527007
when i first bought my car it was pretty standard, am now running FMIC, full 3" exhaust with nismo dump and front pipe, SAFC and turbo smart boost controller, and am now running a very nicely tuned 251rwhp. 11psi.
have heard that the standard turbos are good for around 13-14psi, anything above that and you risk damage to the turbo, ie: disintergrating the turbo exhaust turbine in my case. My standard clutch also had to go, wasn't worn just physically couldnt clamp hard enough.
also just a note, my housemate also owns a r33 with a similar setup, only he managed to score a Mine's ECU (i'm o so jealous) and at 13.5 psi, it's good for 301rwhp.
https://www.sau.com.au/forums/topic/264579-modifying-r33/#findComment-4527165
  • 1 month later...
im in the same boat wanting to get abit more from my R33, im new to this but i can pick up on most of the lingo but what exactly is "safc2 / power fc" mean? im guessing its got something to do with fuel management?
also just quickly, what turbo do series I, R33 GTS-t's come with from factory?
mine has been high flowed and will be for sale shortly when i fit a GT35 to replace it if anyone is keen, i dont know what its worth but the purchaser can come for a drive to make sure its ok before i remove it.
Gonz.
https://www.sau.com.au/forums/topic/264579-modifying-r33/#findComment-4601198
Gonz.
powerfc is a full replacement ecu
safc is a fuel controller.
you can even get a boost controller addon for a powerfc, they are great ecus but very very hard to find an r33 one because once people get them unless they write it off they wont sell it they are too good.
theres a great thread in the tech section on powerfcs if you want to do some research, they are a great unit, but around 1200+ for the unit with handset afaik
Edited by Sillabaa
https://www.sau.com.au/forums/topic/264579-modifying-r33/#findComment-4601375
2nd hand. cheap and good for his budget
Yup, I just bought a second hand SAFC2 last night for $250. :nyaanyaa:
I Just gotta save for fuel pump, boost gauge, fit the the MBC, then get it tuned. Expecting that to be done around Late July/early August. I'll be happy with around 260atw. Atm it does 200atw on 7psi.
https://www.sau.com.au/forums/topic/264579-modifying-r33/#findComment-4607408
i got a PFC and 600 cc injectors sitting right next to me. hopefully get it tuned by Aaron at Intune Performance when he gets back from Dubai. he's gone over to tune some cars and SEMA is on over there. That should push me up to 340 to 350 rwhp then that's it, no more power mods. need to get the rust cut out and brakes need going over and finish of the body kit. then no more (maybe).
https://www.sau.com.au/forums/topic/264579-modifying-r33/#findComment-4607552
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
