^^^ How True! :yes:
THE IMPORTANT THING TO NOTE IS THAT THE ASSEMBLY POINT IS NOW...
"SYDNEY INTERNATIONAL REGATTA CENTRE" 9.30-10.30am
Old Castlereagh Road at Castlereagh ie North Penrith
great brochure.
I am concerned nobody will have a chance at winning those award categories so, can we add..
"Information Overload" awarded to the cockpit that looks most like a flight deck
"Auto Wash King" awarded to the car with the most visible cobweb scratching
"Pimpin aint easy" awarded to anything with 20" wheels, spinners, etc
"Bozozuko master" awarded to anything, well, Bozozuko
"Most incomprehensible ICE" awarded to the car with the most original JDM navi and stereo trinkets with no english language modes
"Least Likely To Idle" awarded to the car with the least stable idle
"Petroleum Liberation" awarded to the car pumping the most unburned fuel out the tail pipe (judged by number of seconds required to create actual tears)
"Defect King" awarded, by someone in cop fancy dress, to the car with the most clearly visible/audible defectable items
This way I feel that most attendees will believe they have a shot at at least one award on the day :yes:
well actually you deserve it too Nick.
...been told you've been whispering in the ears of Hills M/S, Powerplay, Croydon RD etc
It starts at Regatta ctr Penrith right? 9.30am right?
Are you thinking of coming Delta Force?
By all means just turn up, i'll add your name to the attendance list.
Check out the thread for any other details:
10th Anniversary R34 Cruise
^^^...maybe a tad less than 100 leaving Sydney International Regatta Ctr at Penrith
Congregating at around 9.30
Briefing at 10.15
ETD at 10.30
ETA Mt Wilson 12 Noon
Good to have you in your 'black beauty' Denis
ZOMG !#!$!$$ 100 ??? you serious ? Holy crapola batman .. I thought it's gonna be like 20 cars max. Man this thing will be massive ;) Can't wait!
I prefer to call 'her' The Reaper :D
great brochure.
This way I feel that most attendees will believe they have a shot at at least one award on the day :P
Hahaha, very good post!
Ill be going for the least likely to idle and the petrol liberation categories. Stand behind my car to see why.
great brochure.
Yeh I lmao ...
...but Skaifie won't sign 'em ! ! !
If weather is a bit drizzly, we're still "ON"
If it's rain, the Event will be delayed ONE week.
Wet weather up at Mt Wilson will mean that the Demonstration by Sensei Hans and Sensei Dave after lunch will be cancelled due to safety reasons. :D
On sunday cause i have to drive passed the mount wilson turn off on the way 2 pick nick up ill see wat the weather is doing on my way passed and let every1 know when i get down there or when i get coverage.
Please see attached. Any questions just post them up here. Print and bring it along with you if you wish.
cheers
Eugene
hi eugene i will be coming if it's not raining thanks bill (eat.430) blk 99 v spec
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
