Hi guys im wrecking a damaged 1999 r34 manual sedan. Car is classed a repairable writeoff, which mechanically is perfect and still drives with no flaws. Parts which wont be available are manual gearbox, pedals, tailshaft, leather manual gearboot, steering wheel and all manual plastics.
Engine has 95,xxxk's on it and is in excellent running condition. Will be leaving engine complete in car as would like to give people the opportunity to hear it run before they purchase it, once we've agreed a deposit will be taken and engine will be removed. Engine has never been boosted and was recently serviced.
A lot of part which will fit on coupes. Front end of car is very straight, eg front doors guards bonnet and even has the r34 original plastic factory lip.
Car has a what looks to be 3inch front pipe from turbo connected to a high flowed cat 3 then connects to a 3 and half inch exhuast from cat back all mandrel bent. A bit damaged but still has a very nice sound.
Car also has xennon headlights which are in great condition and work perfectly. Also R34 mats available.
R34 GT-T auto will be available soon. All windows also available just rear windscreen gone.
Too many parts to list but if your after anything just pm me with your contact number and what your after and ill will get back to you asap.
Car is located in northern suburbs, Thomastown. More than happy if you would like to view the car.
Cheers.
Edited by DRFT31
https://www.sau.com.au/forums/topic/265152-vic-wrecking-complete-1999-r34-gt-t/
  • Replies 104
hey mate. just after a few interior parts.
1. din pocket (if genuiue r34 one)
2. is that rear cup holders i see on the center console underneath the rear ashtray?
3. driver side A-pillar trim (if it fits a 2door)
thanks mate
Pm's replied, may also trade parts with someone if you have a nismo 300K Cluster, also Nismo guages, nismo oil/raditor cap and power fc. Also rear r34 lip
Thanks!
Edited by DRFT31
Pm's all replied. Send me your offers and the parts your after cheers. :(
May also swap parts for a ps3 console. Cheers.
Edited by DRFT31
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
