huddy Posted April 12, 2009 Share Posted April 12, 2009 dont have pics... but hoping someone knows what i'm on about... it's a metal box under the parcel shelf in ceffys. WHAT IS IT???? someone suggested Hicas related???? Link to comment https://www.sau.com.au/forums/topic/265181-what-is-that-box-under-parcel-shelf/ Share on other sites More sharing options...
works 510 Posted April 12, 2009 Share Posted April 12, 2009 If you dont know something ceffy related, no one will I always thought it was a speaker amp for the stock stereo system, i'll have a look tommorow Link to comment https://www.sau.com.au/forums/topic/265181-what-is-that-box-under-parcel-shelf/#findComment-4529846 Share on other sites More sharing options...
konect Posted April 13, 2009 Share Posted April 13, 2009 Oh good one! My new ceffy has this but my old one didn't...they were both HICAS equipped so not sure about that one :S Link to comment https://www.sau.com.au/forums/topic/265181-what-is-that-box-under-parcel-shelf/#findComment-4531182 Share on other sites More sharing options...
BenA31 Posted April 13, 2009 Share Posted April 13, 2009 My old R32 4 door had 2 boxes under the parcel shelf, one for the HICAS/Steering (steering was heavier when disconnected), and another which I believe was some speaker amp. My ceffy has neither so can't help sorry.. Link to comment https://www.sau.com.au/forums/topic/265181-what-is-that-box-under-parcel-shelf/#findComment-4531204 Share on other sites More sharing options...
daisu Posted April 13, 2009 Share Posted April 13, 2009 R32's have the HICAS computer under the parcel shelf, same with the speaker amp. Cefiro's have the HICAS computer mounted above the ECU adjacent the glovebox, and the speaker amp is mounted under the parcel shelf. Link to comment https://www.sau.com.au/forums/topic/265181-what-is-that-box-under-parcel-shelf/#findComment-4531437 Share on other sites More sharing options...
huddy Posted April 13, 2009 Author Share Posted April 13, 2009 awesome, cheers guys - in the bin it goes Link to comment https://www.sau.com.au/forums/topic/265181-what-is-that-box-under-parcel-shelf/#findComment-4531755 Share on other sites More sharing options...
Lum Posted April 15, 2009 Share Posted April 15, 2009 Some questions about this. It's an amplifier, but it's accepting an amplified signal already, ie the speaker output from your headunit which will typically be 22W RMS, however the rear speakers are only rated for 8W RMS. I haven't looked at the front ones. Does it just drive the rear speakers or does it drive the front ones too. If it's just driving the rears then is it perhaps a high pass filter and the rears are just tweeters with the fronts being full range? If it is actually an amplifier and drives all 4 speakers is there any way to trick it into accepting a line-level input as this will allow me to simplify my Car PC install dramatically as I'll just need to glue my USB soundcard to the amplifier and make up some leads rather than do a full amp+speakers installation. Link to comment https://www.sau.com.au/forums/topic/265181-what-is-that-box-under-parcel-shelf/#findComment-4534410 Share on other sites More sharing options...
CeffyNSW Posted April 15, 2009 Share Posted April 15, 2009 Guys I pulled one of those boxes out of a ceffy with ABS and assumed it was for the ABS as I have not seen it in any others. Regards Link to comment https://www.sau.com.au/forums/topic/265181-what-is-that-box-under-parcel-shelf/#findComment-4534462 Share on other sites More sharing options...
a31lunacy Posted April 17, 2009 Share Posted April 17, 2009 the box is the rear amp it drives only the rear speakers i removed mine and spliced and soldered the wires together because it stuffed up and i wasnt getting a signal to my rear speakers any more its useless most decks perform better than 80's junk any how Link to comment https://www.sau.com.au/forums/topic/265181-what-is-that-box-under-parcel-shelf/#findComment-4540735 Share on other sites More sharing options...
huddy Posted May 3, 2009 Author Share Posted May 3, 2009 ok... so i removed 2 boxes today... (car did have hicas / abs etc..) are they both amplifiers????? one is a small one about 8cm x 3cm taken from under parcel shelf on drivers side moreso the other is about A5 size... taken from just off centre moreso toward passender side from under parcel shelf. they both for stereo??????????????? ta Link to comment https://www.sau.com.au/forums/topic/265181-what-is-that-box-under-parcel-shelf/#findComment-4571959 Share on other sites More sharing options...
Lum Posted May 3, 2009 Share Posted May 3, 2009 the other is about A5 size... taken from just off centre moreso toward passender side from under parcel shelf. My car only has one, and it's this one. I don't have HICAS. HTH. Link to comment https://www.sau.com.au/forums/topic/265181-what-is-that-box-under-parcel-shelf/#findComment-4572139 Share on other sites More sharing options...
Ceffy_SA Posted May 4, 2009 Share Posted May 4, 2009 Mine doesnt have any... I feel left out lol Link to comment https://www.sau.com.au/forums/topic/265181-what-is-that-box-under-parcel-shelf/#findComment-4572300 Share on other sites More sharing options...
DanShirts Posted May 4, 2009 Share Posted May 4, 2009 Is there a part number on it? If it does, fast is your friend. Link to comment https://www.sau.com.au/forums/topic/265181-what-is-that-box-under-parcel-shelf/#findComment-4572555 Share on other sites More sharing options...
huddy Posted May 4, 2009 Author Share Posted May 4, 2009 I do have part numbers... never used that FAST thing - can anyone help?? big box - 47850 71L00 (and has 9Y06 underneath) small box - 1700 1 73L00 then A63-000 162 underneath then 9Y03 underneath Link to comment https://www.sau.com.au/forums/topic/265181-what-is-that-box-under-parcel-shelf/#findComment-4572634 Share on other sites More sharing options...
a31lunacy Posted May 5, 2009 Share Posted May 5, 2009 one in the middle is the amp the small one well i don't know but if ya remove it and the car still runs and performs as usual then bin it Link to comment https://www.sau.com.au/forums/topic/265181-what-is-that-box-under-parcel-shelf/#findComment-4575803 Share on other sites More sharing options...
bbe Posted May 24, 2009 Share Posted May 24, 2009 i have 3 unidentified boxes lol,,, huge on on the passenger side bigger than computer silver with 2 looks another in the middle ( the amp i think ) and 1 on drivers side much smaller with just 1 loom to it ? anyone know what these are yet ? Link to comment https://www.sau.com.au/forums/topic/265181-what-is-that-box-under-parcel-shelf/#findComment-4613664 Share on other sites More sharing options...
SirRacer Posted June 7, 2009 Share Posted June 7, 2009 whats the one in the drivers kickpanel? Link to comment https://www.sau.com.au/forums/topic/265181-what-is-that-box-under-parcel-shelf/#findComment-4642093 Share on other sites More sharing options...
Lum Posted June 7, 2009 Share Posted June 7, 2009 whats the one in the drivers kickpanel? I have that one too. Since I've never found any mention of it anywhere, my guess was it was the 4WD controller. Is yours an RWD Cefiro, thus proving me wrong? Link to comment https://www.sau.com.au/forums/topic/265181-what-is-that-box-under-parcel-shelf/#findComment-4642611 Share on other sites More sharing options...
SirRacer Posted June 8, 2009 Share Posted June 8, 2009 mines a poverty spec rb20e 89 model. automatic though so it could be to do with the auto trans???? Link to comment https://www.sau.com.au/forums/topic/265181-what-is-that-box-under-parcel-shelf/#findComment-4643810 Share on other sites More sharing options...
daisu Posted June 8, 2009 Share Posted June 8, 2009 Pretty sure the behind the drivers side kickpanel is for the auto gearbox. Link to comment https://www.sau.com.au/forums/topic/265181-what-is-that-box-under-parcel-shelf/#findComment-4643831 Share on other sites More sharing options...
