  • 3 weeks later...
They are all the same, the later year of car you get meaning its a newer engine (Overall car).
But there were different levels of R32 GTR's.
22nd May 1989 was the release of the R32 GTR (Standard Model)
22nd February 1990 the NISMO Edition was released based on the Standard Model with a Nismo body kit to improve the look, cooling, aerodynamic and down force of the car.
19th July 1991 the R32 GTR N1 was released. N1 = Race Spec engine, which means it was stronger then the standard R32 GTR engine and was more refined + the upgrade of Brembo Brakes.
3rd February 1993 the R32 GTR V-Spec (Victory Specification) was released. Based on the standard model but came with Brembo brakes and a retuned ATTESA E-TS system (Same like the Nismo and N1 R32 GTR's).
Came with 17" BBS wheels with 225/45/17 tyres.
14th February 1994the R32 GTR V-Spec II was relased. Based on the V-Spec but came with wider tyres of a size of 245/45/17.
Whilst building the upper level models, I assume the Base Model was still in production.
https://www.sau.com.au/forums/topic/265328-r32-gtr/#findComment-4563927
There was an update where there were minor mechanical and interior changes. The interior changes are small, like the centre console surround went from smoth finish to rough-style plastic.
I don't know the details of the mechanical changes other than the clutch, but that change occured arround 90/91??
https://www.sau.com.au/forums/topic/265328-r32-gtr/#findComment-4565579
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
