now thats an out of the ordinary kit right there! wild look for sure!
But it reaks of overdone to me as some of the lines match poorly, giving it the batman look. I know its a wide body kit and they tend to do that, but i think its the upper door line and the mix between sharp edges and curves at seemingly random places thats turning me off saying its top notch! What do you think Jap Muscle??? are ya digging the flow line near the wing mirrors???
One things for sure that right there would turn heads everywhere it went!
Edited by TR11KY
i defiently do like the rear gurads but like what you said, not a big fan of a few things like the front guards, just a bit to sharpe and overdone. also not a fan of the front bar.
ideally id be doing something like that but replacing the front bar and guards.
with the amount these things are worth maybe you might wanna go custom?
+1 uras dosnt do it for street cars inho, have u heard of sunline racing?
Hell Yeah!
The Sunline Racing is one tuff mutha f**king R34 GTR.
C-West N1 Type III Front bar with modified front guards based on the Nismo Z-Tune ones.
Side Skirts seem to based on the C-West and the rears are pretty much bolt on wide rear guards.
With a nice Satin paint job = Looks mint!
But this is body kit for a 2 door R34, I think he wants a 4 door kit.
that kit is also ment to fit gtr's not gtt's and also that kit happens to be made completly from carbon fibre, from memory the front gaurds, side skirts and rear gaurds will set u back around $3700 then u need to use your own front and rear bars
also its the same kit being used by the high octane boys, they used a different front bar tho
Edited by UWISSH!
na looking 4 one 4 a 2 door just droped a rb26 in her so i think might be time 2 do sum body work i resprayed it bout 2 years ago so time to go wide as i want sum fat dish rims on her
crossfactory 2dr kit...
www.rhdjapan.com
expect to pay 10k delievered
there is a bodykit thread for R34's in this section, do a search for it, should have most kits you will find for an R34
Got the Cross Factory kit here original and hand crafted in Japan.
Got a thread selling em cause they costly to put on and ran out of cash after getting em all the way here so it might be of interest to you.
Although your after a 4 door kit...the front guards should fit no problem if you wanna buy em off me.
threads in the sale section PM me if interested.
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
