Hey guys,
Wrecking a white R32 GTR, minus motor and box, front brakes and some interior bits and pieces. Damaged drivers side door and gaurd
PM, text or ring me on 0438911374
Cheers,
Michael
Sorry guys, also 1 pair of Garrett 2860's and other engine parts.
Am dropping turbos off today to get a written report on their condition.
Also 2 sets wheels
Also 2 sets wheels
Hey man, still interested in turbos, let me know how the report comes back, gimme dibs... lol, still interested in a set of rims, dont let that guard go either, cheers Damo
Where abouts are you located, and would you have the stock exhaust from the cat back? Cheers
Dave
Hey mate,
Located in sheffield, which is 20 minutes inland from devonport.
I think the exhaust is stock but it has had an apexi stainless steel muffler welded onto it, not too sure though.
Will check in morning and get back to you if you wish.
are there still seats? if so what condition are they in? if madaz doesn't take the turbos i will
Hey mate,
Seats are still there but the drivers seat and the framework is all bent up from where he hit the pole, passenger seat is in good nick though
Cheers
The guy wasnt too keen on giving a written report without stripping them right down and rebuilding them which would then cost me heaps and i would have to sell them for the same as a brand new set would cost :blink:
But, he gave a verbal to me and said that they are in good condition etc and suggested bringing any potential customers down there with me and the turbos so he can give them the an assesment of the turbos face to face.
Still thinking bout the rims, will let you know in the next couple days, still got the guard too if you still want that held
Cheers
you have the left front inner guard? and the left and right brake ducts?
Still got the inner guard, yours for $20 if its the piece im thinking about???? The plastic piece under the wheel arch
Dont know what you mean about the brake ducts???
They the piece of mesh sorta thing in the front bumper?
the bit of plastic that goes between the wheels and the front bar. and the brake ducts screw to the bottem of it. you can see the rhs inner guard in the pic.
I was on the right track then, i thought i was, just wanted to make sure we were on the same page. No brake ducts on either of my skylines, the grey one or the white one, maybe that year didnt come out with them?????
Amyone know????
mate do you have the front reinforcement bar?
The bumper bar reinforcement part? The piece that sits in behind the plastic bumper which you bolt onto the car?
I thin k we are on the same page but i just like to make sure
Cheers,
Cheers,
yes thats EXACTLY what im talkng about
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
