ive been around skylines for years...but this one was a little weird
r33 rb25det
SOUNDS like its running on 5 cylinders on idle
SOUNDS like its running on 5 cylinders when you go to take off and let the clutch out
at about 1500rpm BAM dissapears!!! and runs PEFECTLY
can run as much boost as you want ...rev to any limit or do anything you want
its like under 1000rpm to 1500rpm it sounds like its running on 5???
o2 sensor?
https://www.sau.com.au/forums/topic/265870-really-weird-problemany-help/
See what you've done, God! I warned you this would happen when you invented the O2 sensor - now the O2 sensor is the cause of every single problem in the modern EFI engine!
heyhey! - have you bothered to analyse which - if any - cylinder is misbehaving at low rpms? Have you checked that the VVT solenoid is working?
it used to run fine...but just sort of happened
i thought if it were plugs or coils...wouldnt it be doing it all the time?
BLIND ELK---- havnt found which cylinder...as it only runs on 5 when letting the clutch out... that tiny moment of initial take off
havnt checked the vvt solinoid will do that today
Edited by heyhey!
well until you workout which cyclinder is missing - no-one can help
Even then, once you FIX the once that is causing the problem, you'll find you dont have one anymore...
if i knew which cylinder was playing up IF ANY do u think id be posting here asking for anyones help???
i ask the question incase anyone else had been througha similar problem....
or for help from people that had ideas... not useless comments
as i said above....it SOUNDS like its running on 5 cylinders very breifly on take off...very very breifly though ( it may not even be running on 5 but sounds that way)
then runs unbelievably well for the rest of it
constructive ideas or people that have had a similar problem would be a great help
3lit3 32 ill look into this
Edited by heyhey!
Well how about you go and find out? Like i said...
your amazing...i went out and found it was cylinder 1....and now just like you said...its FIXED!!!... i didnt even have to touch anything!
NOT
what im getitng at if it is cylinder 1 ,2 ,3,4,5,6, what difference does it make if i have no idea what causing the problems
HENCE why i ask for opinions on THE problem...not which cylinder it is
for example ...oh that sound like an injector sticking problem i had in my old r32
example 2 ...oh that sounds like a dirty 02 sensor problem i had in my silvia
etc
Yeah you need to chill out a bit!!, hey hey!? is having a bit of trouble and is simply asking around for some advice and isn't that what this forum
is for!! yes maybe it is hard to give advise to hey hey, as there could be a number of reason for what it is doing but maybe some where to start would help instead of being a smart ass
+2 I'm with Punk72...
R31Nismoid, You usually have contructive ideas...bad day? :blink:
In regards to the problem, i'd suggest check your plugs first as it sounds like they may be fouling on idle then cleaning themselves as the revs go up. Also you may have the wrong heatrange...what plugs you using?
We can suggest generic solutions all day, but knowing which cylinder is important.
See if you can get access to someone with DataScan or equivalent & do a software-based power balance test at idle.
It may just be a dud plug, but do you really want to pull them all out, change them and still be wondering what the problem was?
Where are you located?
Hey let's not beat up on Nismoid here.
It is extremely important to know what cylinder a missfire is on. You simply cannot diagnose a missfire unless you know this.
It's a very valid statement to make as we are all here offering advice for days and days, using our own time, and after 5 days of rigorous testing you turn around and say 'oh I found the problem fellas, it was missfiring on cylinder one because there was a slightly broken wire in the injector plug at the terminal'
FUUUUUUUCK!!! - is what everyone says
If you are talking about some kind of shudder when you take off, could it be something silly like clutch shudder?
Also, if you have a valve seating problem, it will only be present at idle and the beginning of throttle (if the leak is tiny) but the missfire will definitely be there at idle.
Is it there from idle all the way up to 1000rpm? or is it fine at idle and just there once you try to take off?
see everyone is split
im saying if i knew which cylinder it is i wouldnt be posting ...i would have found the problem and fixed it the second it happened
you guys are saying find the cylinder and then u'll find the problem
im saying...ok its cylinder one! to solve this issue
now what would cause a car to miss under 1000rpm on cylinder one.....any ideas?
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
