ahh sorry i should have explained better, yeah upgrading from the stock dump is a good idea. but i rekon changing from a 2.5" dump to a 3" will do stuff all. there is no back pressure required on a turbo car, there is already enough there supplied by the turbo :)
if the pipe is TOO big, especially off the back of the turbo, then the air wont flow away from it, it will come out the back and 'billow' around and create flow problems. the air is still hot and expanded already, so velocity is required (more so) to move it away from the back of the turbo faster, as it cools, i guess it doesnt matter, its waste anyway........
any one know if there are tuned length headers available for a VQ25DET?? i got some wicked spool times when i changed my manifolds on SR20s
  • Replies 73
Haven't come across them yet.
In fact, I haven't come across many heavily modified VQ25DET's.
Edited by iamhe77
i guess there isnt much room in there to play anyway. plus it will generate more under-bonnet heat too........... hmmmm
mmm under-bonnet heat....
I do like Masa's partial solution to the heat issue with the externally venting front quarter panels.
Dolphin made a vented CF bonnet, but I think that productions ceased on that a while ago...
Don't forget that the right manifold is coming around the back of the block between the fire wall and joining the left manifold at the turbo.
It would be very difficult to tune the length too much unless you go twin turbo.... Now there is an idea...
Ahh yes.. TT. An idea that has been kicked around in my head for a while.
Would need pretty decent $$$$$'s to do it and, preferably, another intake box on the left of the engine as well as 2 return piping FMIC's... ooh yeah
actually would it REALLY be all that much work. after thinking about it, just a dual input FMIC and piping from the turbo to suit might do it. i mean besides all the exhaust manifold piping etc and the turbo mounting, oil and water lines, exhaust..... a lot of work, but possible!
lol. Anything is possible with the right $$$'s and expertise
Very noice.....
and if I may ask, what did that cost you? Also, which of the XForce Mufflers is that one?
Much as with my R33, the fake trims on the dual pipes is starting to get to me, different is that with the R33, a swap to a full GT-R cat-back with proper dual pipes was only $120 and 1 hours work fitting it away..
Edited by nickcorr
is it loud?
It's got a nice tone, real V6ie sort of noise, actually same as the big apexi but quieter. I was told it was legal ( < 95 Db's) ...and it indeed passed rego inspection yesterday.
It still sounds nice, actually I can hear my turbo and intake sucking air more clearly now and the BOV sounds louder too :)
Understandable.
Have you noticed that in the case of the OE "dual" pipe muffler, only one of the pipes is actually spitting out gasses?
The other is just for "show".
Fark!!! Just checked...
Only the outside one is connected to anything!! I feel cheated.. :P
At least the OEM R33 GTS-T muffler was a genuine twin outlet.
On the plus side, a new muffler, now counts as a performance mod, rather than just a cosmetic change... :P
Understandable.
    • Thank you for the feedback bro. Looks like it’ll have to stay off the road till it gets an ecu
    • Only if you do not You will not be able to drive it with any serious load without risk of it pinging, which will either slowly or rapidly kill it, depending on how bad it is.
    • Hi guys, I’m new to the GTR scene. Picked up an R33 GTR earlier this year that needs a lot of love. I’ve been going through the hot side, changing all the gaskets and while it was all off I managed to score a set of -9s. It still had the stock ceramics so I was pretty happy to get the 2860s.  I live in a small country in the pacific with 0 performance car scene. No dyno’s no performance parts, let alone stock parts for a skyline. I order everything from Australia and do it myself. This means I’ll be running the stock ECU. Maybe down the track I’ll get an aftermarket set up and do a remote tune.  Will the car run -9s on stock tune safely?  I have a very heavy foot so I really hope so 😂   thanks guys
    • perfect, no rush to address the leaking bush then, it's not doing much/anything
    • I'm not sure if it will bolt up, but.... I'm reasonably sure that the ID of the runners is somewhat smaller on the NAs. So it probably wouldn't be a good match at the flange where the top and bottom meet. So that would be a reason to not do it. And the skinny runners would be the bit you're keeping, which would be a reason to no do it. You'd want the big runners if you were doing any work to swap stuff. Why not just use what you've got, like nearly everyone else who has +T'd an NA? You don't need or want the TCS throttle or other stuff that is specifically DET inlet/crossover.
