OK, interested in the JJR pipe. Would you take $120 cash on pickup? Could probably get there in the next couple of days. If yes, PM some contact details - I can;t send PM, since I've got less than 10 posts... bugger
  • Replies 54
I'm wondering if you have the sensor that goes behind the steering wheel that connects to the steering wheel, they told me it was the srs sensor?? Pm me info and price
Got alot of parts for sale which i have accumulated over the years. Everything is in good working order unless stated otherwise. Located in Emerald, Victoria. Photos will be put onto photobucket
http://s160.photobucket.com/albums/t177/Shano3000/ will take photos of parts on request aswell.
Wrecking complete R33 GTS-T.
RB25DET Complete Engine 100,000km. Will include everything minus engine loom. Very good condition with stock turbo. Had its major service 3,000km before crashed. All belts, idler tensioner, water pump etc 3000km old. Was running fine after crash - $2000
Gearbox, good condition - $1300
3,000km old exedy heavy duty clutch - $150
Tailshaft - $150
Diff - $150
3" turbo Back exhaust. Bellmouth dump/front pipe into jasma muffler - $400
FMIC Return flow kit. Includes generic fmic with Blitz return flow piping and all clamps/joiners. No holes need to be cut - $300
Front brakes With rotors and pads. Pads still got plenty left. Good condition - $350
Rear Brakes with rotors and pads. Good condition - $150
2 X Starter motors - $50 each
Air Con pump - $50
2 X Gearbox Mounts - $80 each
Rear Axels - $50 pair
Rear bar painted white. Good condition. Appears to have been re-sprayed - $100
Rear bar Reo - $40
Boot lid with Series 1 spoiler - $50
Tail lights - $50 each
undertray stone guard. Has a few small tears - $40
Car mats. Complete set - $50
Drivers side Head light. Off a 4 Door, chrome surround. A little bit yellow. $50
Lots of other parts available. Just let me know what you want and ill get back to you with pics/price.
RB30DET Parts:
Rb25de non vct head from a R32. Head has been cleaned, new valve stem seals, heavy duty springs for turbo application and surface machined flat.
Inlet manifold, injectors and fuel rail, throttle body and all bolts/miscelanious pipes etc - $650
Good Condition S2 RB30 Bottom End, fully assembled. Brought as working motor and stripped head etc off - $75
Rb30 S2 block, disassembled. Includes crank, rods, cradle and block - 6 pack of Bundy
New ACL Duralite cast RB30e pistons and rings, 1mm oversize. Suitable for RB30DET conversion. Will give compression of around 8.3-1. $250
New ACL Duraglide engine bearings. to suit RB30. .25mm oversize. includes rod bearings. $50
RB30 complete engine gasket kit with Headgasket. No sump gasket included - $100
RB26 Oil Pump. Came off R32 GTR. $100
RB20DET Exhaust Manifold. Will bolt to Rb25de head. $40
Will post smaller items at buyers expense. Pickup only for gearbox, engine etc unless you organise everything and pick-up from my house. Contact through here, PM, or message/call me on 0422816780. Cheers, Shane.
PM Sent
Thanks for that - still can't reply to PM. I'll take the JJR pipe for $140. Can pick up tomorrow evening if that works. Please PM your address and/or number. Thanks
Hey Mate do you still have these available? Can i get some pics of the rear bar, do series 1 rear bars fit series 2?
Cheers
  • 3 weeks later...
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
