umm mines a GTS, so it idels at 500 rpm, around 1000 with aircon and demist on.
I use BP Ultimate. I tired Optimax, but my exhaust kept givin off this godawful sulphur smell.
BTW b4 u post athread next time, search there's been about 6 threads already and 1 poll about which fuel ppl use.
https://www.sau.com.au/forums/topic/26631-which-fuel/#findComment-562770
I have only, do only and will only ever, use Mobil Synergy 8000. Sure it gets a little pricey sometimes but someone once told me that was the one to use for my Skyline. And when he talks Liners, I listen.
I think it all comes down to preference tho. I'm not sure there is a "perfect" fuel to use.
https://www.sau.com.au/forums/topic/26631-which-fuel/#findComment-562976
I was reading a big write up on the quality of fuels in Australia and it had some VERY interesting info in it. Personally I only user Optimax but once my new car arrives I wont be using it anymore. It turns out of Vortex, Optimax, BP Ultimate and Synergy 8000 that only two of these fuels have a true 98RON level - Optimax and BP Ultimate. It is even stated on Mobil and Caltex's web sites that their high grade fuel ranges between 95 to 97 and that’s piss poor!
Another thing I found was that BP Ultimate is a higher grade fuel than Optimax due to the fact they add additives to Optimax to get it high octane levels where as BP is brewed that way and has less aromatics than Optimax. Interesting hey!
As for higher grade fuels - Elf LMS. This stuff is shit hot and can provide up to a 30rwk gain in power in cars like Skylines etc. LMS is available in either 200 liter or 50 liter drums. Price: $4.85 per liter (200litre drum), $5.30 per liter (50litre drum).
As LMS is an unleaded fuel, no CAMS license is required to purchase the fuel only problem is as you can see it’s pricey but well worth it for a day at the drags. Should get a few runs with a 50 liter drum :P
https://www.sau.com.au/forums/topic/26631-which-fuel/#findComment-563224
some of the 'better' octane boosters do provide up to 2.0 points increase. Nulon Pro Strength gave I think about 1.7 in a HPI test a couple of years back and for about $12-15 was the best buy in that dept [octane booster dept].
Adz: Strangely enough I think I find Synergy gives me a smoother idle than BP...strange.
Ward: in terms of price I dont find synergy any dearer than ultimate in my area, they are both around 7 cents dearer than regular unleaded, whilst optimax is approx 8.5 cents dearer...
https://www.sau.com.au/forums/topic/26631-which-fuel/#findComment-563311
Ahhhh I stand corrected. But as you said some of the "better" octane boosters have a decent increase, not all :P
As for the idle I honestly dont know. The information I have is written info form the makers of the fuel, maybe Mobile does idle better?
https://www.sau.com.au/forums/topic/26631-which-fuel/#findComment-563327
thats cool, I wasnt really asking a question about it, I was just stating that because mobil seems to be an inferior fuel [in terms of octane at least] I am surprised it seems to feel smoother in my car as compared to ultimate...I still use ultimate because of the octane level :P
https://www.sau.com.au/forums/topic/26631-which-fuel/#findComment-563345
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
