ANY state, if you're travelling form outside of nsw it's yours for 10,000. will swap for a vy/vz sedan (plus cash for the right one) in the 6, auto or manual, i don't care.
THINGS WRONG: left headlight doesn't work, needs new tie rod end(s?) steering wheel doesn't fit, is on an angle (how i bought it off the last owner, haven't gotten around to purchasing a new one); if you buy i'll be happy to knock a new wheel off the price and the same applies for the rod end/wheel alignment.
MAKE: silver nissan skyline 1995 r33gtst with rb30/25det non vct
rego is due august, which i'll reknew early if someone buys it before august otherwise i won't.
ENGINE: tomei cams 10.2 lift
mahl pistons
acl race series bearings
argo rods
cometic head gasket
garret gt3540 with .82 rear
hks intercooler
3 inch exhuast with titanuim tipped cannon
rpm technoligies spring sprung ceramic button clutch
front facing plenum
sard 770cc injectors
bosch 044 in custom surge tank mounted in boot
spit fire coil packs
z32airflow meter
apexi power fc and hand controller
eboost 2
adjustiable cam gears on inlet and exhuast
EXTERIOR:
18x9 ruff rims with new tyres on rear front tyres ok, brand new rears, dyno chewed them
greddy coilovers
hicas removed and lock bar is in place
new inner tie rod ends
0458225624 - 24/7 call anytime
[email protected]
-Dean.
faster than a gun :P
didn't get ahold of my brother tonight, i'll see about the receipts/certificates though.
i'm aware that it's extremely cheap, but i just wanna get rid of it, before i do something stupid to myself, or such a great car.
edit: also got a pioneer 12" sub and 500W amp for an extra $100 bucks if anyone wants it those, not installed in the skyline, was but i took it out..so you'll be installing it yourself.
Edited by Spaz13
22psi. goes to 35.
only got one sheet handy, which shows an old one of i think 278 or 287 kw, mum cleaned my car out whilst i was away for work and threw out everything in it..sounds like a load of bullshit but hey it's the truth, doesn't bother me if you believe it or not.
i'll upload the other sheet, not keen on doing another dyno just for a sheet of paper as we chewed out the rear wheels last time and it's not worth it.
well i want 100% proof that it has 370rwkw otherwise theres not point making that claim. If i was to come and buy it i would want to see it on the dyno infront of me before i bought it. What do you think?
if you pay for it, deal.
brad, was done around 8000 k's ago.
/edit: maybe less.
Edited by Spaz13
This will not last long. Too cheap.
GL with sale :/
Too cheap for a reason generally
Where are the receipts that were meant to be posted a week ago?
10k for 370rwkw does not add up, thats what a motor costs on its own!
sold.
oh and f**k it's not my fault if my brother is a tight ass and hardly ever comes down to see me.
it was cheap cuz i wanted it gone before i did something else stupid in it.
close.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
