Best Ride Height For R32
hey guys
i've had a look around an can only find the heights recommended for a gtr so whilst it was up on a hoist the other day we set the suspension to that (350mm front and 340 rear if i remeber right)
only problem is the car is now like a boat and im not convinced that its right
(its higher than a ve ss)
what sort of hieght should i go for for best handling but remebering that im in tas and the roads aren't that smooth
Thanks for your help
Tom
im not sure what youre after, or what your spring rates are or anything.. but i have cusco coilovers, 8kg fronts and 6kg rears, its pretty stiff... and my exhaust is about 70mm off the ground at its lowest point.. i have no dramas with getting up and down driveways and speed humps etc. and my handling is pretty good.
want to know the distance from the centre of the wheel to the wheel arch
needs to have 100mm clearance as will be going to qld at the end of the year and they are strict
also has full body kit which scrapes everywhere (vertex kit if it makes a difference)
 Share
    • I'll chime in here with my experience. Motec is great if you have the money and know a good person to support you. They don't really offer retail support and the dealers make SFA margin on the product, so the business model is setup for you to be supported by a dealer. I'm lucky enough to know a guy who's ex Motec and very generous with his time and is a total boffin. In addition to that, I also use Brad Sherriff who's an absolute legend to work with. The downside to Motec is the software isn't very intuitive, pay to play, poor/limited online support and costly upgrades.  I've not owned an Emtron myself but a good friend runs a performance workshop in Melbourne who is an Emtron dealer. They won't be fitting any more to customer cars because of the poor level of knowledge within the Emtron support team and lack of ability to solve issues with the platform. Not to mention the circumstances around the establishment of the product and company in the first place. I've run Motec's since the old M8's back in the early 2000's so I'm certainly not without a bias but I look at it like this. Everyone acknowledges Motec as the best consumer grade product without spending mega dollars on Bosch Motorsport / Life Racing and so on. When you consider the real cost of your car (not what you tell your mrs) the cost difference between an Emtron and a Motec is tiny, why would you compromise over a few hundred dollars?
    • Closer to getting the shit box back on the road. That long hose, took 2 months to acquire. However the rest were all already to go same week I ordered them. For those playing at home, that long hose is for a RB25DE N/A motor, as they don't run a water/oil heat exchanger, the hoses underneath the plenum are much more elegant and not a maze of shit.
    • One thing you may be able to leverage is the fact that the R34 N/A has the same setup as a S15. The S15 also is a car that gets 350Z diff swapped, so they will also likely have this problem. The caveat of course is it's possible the dash is different between the R34 NA and the S15, but the subframe/sensors/axles/diff setup are the same. I can't remember now as it's been too long, but I don't generally think people need to swap dashes between the N/A dash and the turbo dash when they do things like change the gearbox out, turbo their car, manual swap it, it's just not something I've seen mentioned so this could be compatible.
