Hey all,
Just want to compare what results other people acheived from BMT Dyno.
Please also state the mods you have.
Anyway I go first.. Just had my car dynoed at BMT , im sure Sam will remember me ;)
Car:
-Skyline R33 GTST Type-M
Mods:
-2 Stage Boost Controller (set to 11 psi, no spikes)
-3" Dump/Front pipe
-3" Cat
-3" Exhaust
-Apexi SAFC tuned from Sam himself
-NGK Plenium Spark Plugs gapped to 0.8mm
Result:
-127rwkw
Is that abit too low? I know that the BMT dyno is more accurate than all the other Dynos out there and that other dynos run higher. Just wanna see what other people had acheived from BMT :P
https://www.sau.com.au/forums/topic/26690-bmt-dyno-results/
  • Replies 80
ive heard it is more conservative.. i read somewhere a car was put on the bmt dyno and it got well i forget :P but then the same car was put on the dyno at auto salon and it was much higher. Does the word conservative mean more accurate?
i was rather shocked at 127rwkw i must say. the car should me more then that stock
https://www.sau.com.au/forums/topic/26690-bmt-dyno-results/#findComment-563745
It is always hard to say more accuracy but I think all dynos are conservative compared to Autosalon. I dont know about BMT's as I use Ben at RacePace and Simon's at Nizpro that are different but come up with very similar figures that are usually consevative by other dyno's standard.
Mick.
https://www.sau.com.au/forums/topic/26690-bmt-dyno-results/#findComment-563794
yes dude, everything seems ok. turbo spinning, only got stock intercooler though :P i was shocked myself also.. its really weird, timed myself 0-100km using the apexi RSM and scored 5.8sec? my car isn't that sloww as i can feel the pull in it but why 127rwkw that puzzles me.
https://www.sau.com.au/forums/topic/26690-bmt-dyno-results/#findComment-563807
Hey Eric 127rwkw is a bit low considering ur car is an auto with auto u loose 10-15rwkw easy I got 140rwkw when mine was auto with 11psi boost 3" cat back zorst and tuned safc on BGT's dyno about 2yrs ago it could be the dyno itself. ur 0-100 time is pretty respectable so u might actually have more than what the dyno shows that would be my theory anyway.
https://www.sau.com.au/forums/topic/26690-bmt-dyno-results/#findComment-563971
guys just to let u know most older dynos are not very accurate and generally put out a lot higher readings... all the new dynos that are around are genuine readings which u should really go by... it may only be low 120s but i bet it will beat or stay up with cars that have dynoed 180rwkw on other dynos.
https://www.sau.com.au/forums/topic/26690-bmt-dyno-results/#findComment-564030
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
