  • Replies 80
Originally posted by SLYWPN
This dyno is way low for sure!!
RiggaP said he ran a 13.8 or something with a dyno result of 141rwkw... For your car to run high 13's you have to be pushing about 180rwkw plus..
I had my r31 dynoed at Goodguys in bayswater and got 160rwkw @ 12psi and I know my car is probably good for low to mid 14's..
Take it to the track, see what sorta MPH you get
170rwkw for a high 13? i dunno about that...
i only have 142rw according to goodguys and sam ran a 14.08 @ 93MPH running 10psi. When it was on the dyno it was running 14psi... i guess its more the driver than power.
Guest RedLineGTR
OKay your results at the 1/4 mile depends on the driver/conditions/mods/experience etc...with dyno results when your getting shit tuned and added to your car...stick with one workshop then u know how it rates in the kw scene..if u want high readings go to AVO and see what thier dyno reads..they are know for high readouts...like mentioned rwkw dosent always mean alot it depends how u use it and put it down to the ground..
Guest RedLineGTR
tuner also have different styles of how they like to tune sometimes that ask u sometimes they dont... u can tune your car to be reliable and have great responce or u can have it tuned to its full poetenital thoe risking reliablilty depends on what u want and what the tuner and do for u.
Originally posted by pushead
i wouldnt mind now taking my car to the stripes. Want to see my 1/4 times. :P Thanks all for making me feel at ease with my results.
ive got some house paint somewhere u wot have to take it i will bring it to u with a roller... u want 2 fat stripes down the middle or just one? :)
Today just dynoed at BMT, had some dramas coz one of my coil packs did not work above 10psi so at 9psi made abt 147rwkw mods r:
SAFC2
ITC
3" 5 zigen exhaust system cat back
apexi pod filter
ARC FMIC
tomorrow gonna fix up the coil packs and up the boost to 13psi. Will let u guys know the figures
cool man i think my car is running 11 or 13 with 141rwkw at bmt dyno. mods are
SAFC (1 :D)
i have no idea what an ITC is lol
3.5" HKS superdragger cat back with 3" hiflow cat and front pipe
k&n filter
and thats it with power mods i think once your coil packs work and use more boost you should get more power me thinks.
should be good to find out what the results are
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
