hey guys got some bits i wanna get rid off for a GTR conversion.
OEM 2000 R34 GTT Bonnet in black finish - $700 ONO
Bommex R34 GTT Bonnet in black finish - $950 ONO
ADR approved so no defects guys!!! Fibre Glass Material
Both items are located in Melbourne
**please note pics are not of actual product but identical in every single way.**
any questions please ask!!!
Edited by Jap_Muscle
  • Replies 81
hey guys just an update.
after realizing the OEM bonnets were so cheap ive dropped the price down to $400.
or make me a reasonable offer
=D
I appreciate the enthusiasm guys but if your not interested can you please refrain from posting.
Carbon fibre bonnets are illegal which is why some ppl may prefer a already painted ADR approved fibre glass bonnet.
=D
$300 for bonnet, std one. get back to me if youre interested
0402 910 431
If your buying cf bonnets that are fbglass, they usually have a single layer of carbon fibre which according to oficials has the potential to shatter and cause serious harm, which means illegal.
adr approve bonnets are made with certain meterials waraped in fiberglass which is accepted by officials.
If you want more info search it up and please refrain from posting unless you are interested in buying.
No.. Fibreglass absorbs impact better than Carbon fibre.. Look at a F1 car total carbon, hits anything bits fly everywhere. For the record f/g and c/f bonnets are illegal because they often dont use a latch and or it is not as strong as a metal/aluminum etc (except in OEM cases obviously) and they fly up and cause a shattered window at speed & a crash from no vision.
Only ADR approved bonnets are made by Blits im sure this is one, same design.
Edited by DECIM8
Seeing as blitz isnt australian, i would be fairly certain its not ADR approved, as it would have to pass an australian crash test.
I'm not talking about blitz i'm talking about blits which is austrlian. Please remove your post
He said Blits not Blitz and according to their website they have the first adr approved fibreglass bonnets in australia
http://blitsautomotive.com/
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
