The central loccking isn't working on the car ( Stagea M35) and both key don't seem to do anything. I was wondering if it's the batteries. I took the single screw out of the remote part of the key but it doesn't seem to want to come apart. Any hints?
https://www.sau.com.au/forums/topic/267017-how-to-replace-key-battery-on-m35/
Well if its the same as my S1 key then once you take the screw out the case is held together with clips so i used a stanley knife to make a small opening and then put a small screwdiver in the gap and turned it and it came apart (my beatery was a Panasonic CR1620 3v).
If your central locking doesn't work off the key (and the key opens the door OK) try the lock buttons on the door and see if they work.
It is possible to disable the remote locking ( I saw the instructions somewhere) but I don't know how to re-enable it if that is what has been done.
yeh remove screw and lever inbetween cover at base of key shaft. part number mentioned is correct.
The guys are spot on. Remove screw, use a stanley knife or similar on the side of the key, run the blade along the join and twist gently and it pops right in half. The battery inside is a Panasonic CR 1620 3V.
When you get a chance, please add this to the M35 info thread for future reference it anyone needs it :/
Thanks mate, I think my battery is getting low so I may need to do it very shortly.
Im not sure, I got it programed in Japan b nissan when I bought it. Might pay to check with Nissan here as they would have to do it for other cars.
there is a thread somewhere that you do it yourself
this was stolen from chooks thread .it didnt take much searching guys .here goes
nissan remotes can be programmed yourself by following some steps, so thats not a prob, of course dealers would never tell you that.
Just get in your vech , close all doors. Using your power lock switch , lock all doors. After doors are locked take your Ignition Key and insert it and remove it from ignition switch in a slow fashion , but consitant pace. (97 and earlyer are fast) When you see the hazzard lights flash, put key in ignition switch and turn to the On postion .. Do NOT CRANK or you will have to Start over .. After in the On postion .. Hit the Lock button on remote... Hazzard lights should flash..( note..you have to reprogram all remotes when adding a new one , if you don't your old remotes will not work ) If your doing just the one , turn igntion switch off and unlock door and get out and try it. If you are doing more than one. While still in Vech with Key on . After you hit the Lock button on Remote and hazzard light flashed .. with key still on .. use master lock switch unlock doors and relock and then hit Second Remote, Lights should flash again , repeat if adding a 3rd remote.. after done just turn key off and unlock door and get out and try.
all together now thanks chook
  • 1 month later...
Hi,
I have a M35 ARX build date 06/02, do I have a transponder type key where I have to get a special code from Nissan Japan?
Or can I buy your guy and do the steps to get it to work for central locking?
My key looks exactly like the one picture in the thread, and the same battery.
Just got a steel key cut and it turns the car on, so my car hasnt got the transponder. However I would like to find a key that has the 2 buttons for central locking. Anyone have a part number/where to buy for this so that I can do the steps listed above thus have a new remote key! Cheers for the help.
Not quite sure where you're at. You say you have the right key (with two buttons). Do they work? If not have you tested or replaced the battery? Having done that if it still doesn't work have you tried the steps above (from mike's post out of Chook's thread). Why do you think that the fact that the new key you have had cut turns your car on proves that you haven't got a transponder? Or is it the case that you do have a key that works and you just want a spare? Have you PM'd Danwatt to see if his is still for sale? new ones are about $300 from Nissan.
Hey,
Sorry if I wasnt clear. I have a key remote right now that controls the central locking of the car that works. I was trying to get another spare from Nissan today and they are charging $224, a bit steep just for the central locking. I was worried that my key has a chip in it, so to figure that out i just got a steel key copy of the remote and put that key in the house and tried to start the car.
I guess installing a new alarm/immobiliser that can use the existing central locking motors would be the best bet as you avoid getting raped from Nissan parts. I will try a pm to him to see how much he is selling it.
Cheers
Couldn't get this to work on my AR-X. Can't get to the stage where the indicators flash..
Don't know if that has anything to do with my Aussie spec imobiliser that uses a "dongle" on the keyring rather than a remote.
Any ideas?
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
