Ok people its time to let my good friend go as i need a upgrade for work purposes (unfortunately)
1996 R33 GTS-t White Manual 122,000 kms.
Car has been serviced reg every 5,000 kms and i have been the only owner in Aust since the car was imported in 2005.
car has the follows mods
HKS Coilovers (adjustable)
HKS High Flow panel filter
Front Mount Intercooler (custom piping back through Std holes, ie not cutting)
Sparco Racing 17'' 235 front 255 rear
Bose Importing Split Dump/front pipe
Catco High Flow Cat
Blitz Nur Spec Cat Back
Exedy Sports Organic Clutch
Greddy Profec B spec 2 Boost controller (car runs 11 psi)
Apexi SAFC 2
Alpine Head unit (inc direct i-pod connection)
Alpine splits and 6x9
Cadence 4 way Amp
other parts that are not on the car : - Std turbo back, Side mount intercooler, Blitz BOV and M's pod filter.
Car is very clean, only blemishes are small tear on drivers bolster and the front spoiler is cracked (it can easily be repaired or taken off and it just bolts over the std spoiler)
$11,900 ono
any questions you can get me on 0412464683 or just pm me.
https://www.sau.com.au/forums/topic/267342-r33-gts-t-series-2-melb/
PRICE DROP $10,500 ONO
THIS IS CHEAP PEOPLE CAR HAS SOME QUALITY MILD MODS ON HER!!
VERY REWARDING CAR TO DRIVE ESP ON WINDING ROADS :(
ONLY REASON WHY I'M SELLING IS BECAUSE I'M GETTING PRESSURE FROM WORK TO UPGRADE!!
  • 3 weeks later...
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
