Hi guys, I have done back to back on a Dyno Dynamics (roller) and a Dynojet (hub). No atmospheric corrections, on the same day, both calibrated, using the same car and the Dynojet was 14 kw (20 hp) higher.
So 431 to 411, sounds OK to me.
  • Replies 175
When I looked yesterday just before the dyno comp it was 50psi at idle, I believe it increases fuel pressure by 1psi per 1psi of boost, but not 100% sure.
One of the GTR's there was running 80psi of fuel pressure on 1000cc injectors, and still ran lean on 652rwhp:D
The Dynojet hub dyno's are very accurate for repeatability, my only comment about them is that the load the car up hard, as there is no slip, and this brought a couple engines unstuck, and they take a long time to setup the cars, which for a dyno comp can be a little be annoying.
Thanks GTS-t Vpsec, I don't have my book in front of me (it's at the workshop), but if I remember rightly an R33 GTST RB25DET runs 36/38 psi standard.
Now 50 psi is 39% higher, 370 cc's plus 39% = 514 cc's
514 cc's = around 514 bhp
514 bhp - 80 hp (losses) = 434 rwhp
Now the 411 rwhp makes sense.
I am no longer perplexed.
PS, as I said in a previous post, I personally don't like "overdriving" an injector more than 10%, it can cause reliability issues.
Well Steve-SST, you issued a challenge.
"Get a PFC on a standard BR25 motor and injectors to run these numbers Mr Sydneykid"
I wasn't worried about this challenge, other than previously posted standard injectors at 40 psi fuel pressure bit....
But since GTS-t Vspec confirmed you are using 50 psi fuel pressure, it's a piece of cake!
So what shall we bet on us achieving this? I was thinking of $1K, but cash is so passe. How about the looser flies to the others city and washes and polishes his car for him and then flies back, same day?
Hi GTS-t VSPEC, maybe I don't have to get a sucker? And why would you think that you were the first? I haven't lost a bet yet, 'cause I only bet when I know I can't loose.
All I needed was the missing bit of information, 50 psi.
This and its associates were all great threads, thanks for starting them and for putting up with my persistance.
I've enjoyed the debate immeasureably too, always great to thrash things out, and hopefully we've given all of SAU some valuable info to make a decision with.
I look forward to when you post a thread saying "Sydneykid gets 400+rwhp on stock injectors":D
Hi GTS-t VSPEC, maybe you should check the archives, we did it in late 1999 / early 2000 with an R34 GTT. We had no choice as there weren't any aftermarket injectors available for GTT's then. We used a Malpassi rising rate regulator and just kept turning up the pressure until it had enough fuel.
As I posted previously, reliability when "overdriving" injectors this much is suspect, we had 2 fail a few weeks later.
So please be careful.
Thanks for clarifying the dyno point GTS-t VSPEC...fair enough,
One query however that puzzles me. Perhaps its wrong and someone can correct me with their experience. I was under the belief that a pressure increase across an orifice such as an injector does not equate linearly to flow, i.e. there is a square root term in there. So for a 39% increase in flow you would need 1.39X1.39 = 1.93, which implies a 93% increase in pressure, i.e 69.5 PSI from 36, not the 50 PSI indicated???
Are you still running the standard exhaust manifold GTS-t VSPEC or do yo have a custom manifold???
I was of the understanding that if its a rising rate regulator, it will increase more than 1 psi for every psi boost, hence the 'rising' rate.
Also, normal fuel pressure regs raise the pressure linearly, 1psi for every psi of boost, same as an adjustable fuel pressure reg, which just allows base pressure to be raised.
Is this right?
hey rb20-calais,
I meant that the pressure by my calculation (rightly or wrongly) would need to be 69.5 + 18 = 87.5 total at 18 PSI boost. With boost fighting against the fuel as it tries to escape from the injector, at 68 PSI fuel pressure and 18 psi boost, the effective pressure across the injector is still only 50PSI...68-18. The regulators just try to maintain a constant pressure across the injector, unless you have a regulator that is greater than 1:1 when you will then add to the effective pressure.
Paul posted early that he had the pumps and reg fitted.Injector life? who knows but we have many GTSs every week in here running many different setups without injector problems.
I don't think any shop in OZ sees more Skylines than us as WA has the biggest import scene in Australia, Fly over and check it out.
WAs soon to be Fastest GTR will be on a GTR plugin Wolf but the Supra we had at the show was not the one with the Wolf the White monster with the Blue stripes and NOS etc has the Wolf.
The Twin GT30ed job is my Drift racing ride for next season and we fitted an SM2 Autronic because we did not have the V4 Wolf on sale when we first built this car.Its on its 2nd life now but as the current ECU is a good thing we will leave it in. Both Supras could not use a Power fc with their mods as theirs to many inputs and outputs needed plus PFC can not drive low impedance injectors without risistors( not a good thing to have to Ad)
or control the Nos that both have or the boost or run dual maps like the white one has.You could not risk tuning a 1000hp motor on a hand contoller as slow as the PFC one or any hand controller for that matter.Wolf ECUs can be reconfigured to most applications so this is were it runs away from the PFC but on a strong road car a PFC is fine.Pauls GTS can switch from 330 to 430 hp in a second so dual maps is a nice thing to have .
Pick your tool but don't bag the other as their is good in both.
Even though maximum power wasn't an initial concern of mine (since I'm not likely to ever to be able to afford a 1000hp+ car), would it be safe to say that at <1000hp the PowerFC is better, and at >1000hp the Wolf is better?
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
    • I _think_ that one has a christmas tree or some other retainer spike into a hole in that panel under it. Come in under it with thin scredrivers and just pry it gently up. If you rip the ears off the retainer pin....so what? Just stick it back down after with a bit of race tape and carry on with life.
    • Here's a pic of the damn thing
