These are off my brothers car which topped out 337wheel kw (about 450Hp) on 1.4 bar (20.5 psi) after we installed the injectors. Please note this this is on pump fuel and with the finial power run and MAP I chose to drop ignition timing to compensate for the inconsistent fuel we have in sydney
No 1/4 mile figures have been done at the creek, however with the Data pulled out of the MoTeC ECU 11.2 and 11.1 were the figures at 195 kph (about 121 mph).
These have been on the car for a year and a half up until a couple of weeks ago these were only run on a measly 1 bar boost due to lack of fuel however we have since fitted 1000 cc injectors, pump etc etc to run up to 20 psi. They ahve done about 21,000 Road Klms
These bad boys are on 20Psi by 4,000 RPM and provide punch all the way to 8500 RPM where power does start to drop off slightly with the current set up.
Best used with aftermarket IC, ECU, Exhaust, cam gears, further intake and exhaust ect etc. If you have the mods you can push an extra 4 psi and achieve more grunt however I chose not to do this.
These are genuine NISMO turbo's not made up local units with full steel shaft that is larger then standard, larger compressor wheels and duel roller bearings.
Selling due to upgrade that should put us in the mid ten ohh bracket
Please do not reply with stupid offers as these cost over $4800 new and are an absolute steal at $2300
If you would like pic's please email me
If amosite is genuine, which i am sure he is, these puppy's are an absolute bargain!
I was lucky enough to purchase a car with BNR34 N1 turbos already fitted in Japan along with a host of other gear. I can vouch for amosite in that these turbos (even though slightly different to my own) are ultra responsive and make a huge heap of mid range torque and response.
I am so happy with my turbos that i dont think i will ever look to upgrade as i cant see any other turbo out performing these type for pure street use...They are driveable, useable and provide a nice wide meaty power range...
Good luck with the sale and for anyone interested, these turbos are the crem del a crem for any serious street car. And if you dont belive me, just look at the latest HPI 7, the top low mount turbo GTR from Phoenix power garage used BNR34 N1 turbos to the tune of 630 odd PS at the wheels!!!
Basically, buy these turbos and you are guaranteed atleast 400RWHP (providing you have pump inject. etc), for a tad over $2000 its gotta be worth it!
  • 2 months later...
Hi,
I noticed you are after a set of N1 turbos to suit an RB26. I've got a couple here in good condition (zero shaft play) for sale - asking $2000. Let me know if you are interested.
Regards,
Chris
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
