In A.D. 2101
War was beginning.
Captain: What happen ?
Mechanic: Somebody set up us the bomb.
Operator: We get signal.
Captain: What !
Operator: Main screen turn on.
Captain: It's You !!
Cats: How are you gentlemen !!
Cats: All your base are belong to us.
Cats: You are on the way to destruction.
Captain: What you say !!
Cats: You have no chance to survive make your time.
Cats: HA HA HA HA ....
Captain: Take off every 'zig' !!
Captain: You know what you doing.
Captain: Move 'zig'.
Captain: For great justice.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
