  • Replies 492
Posted Images
cheers mate! ddrum is a good brand, the drummer from devildriver uses them. i used zildjian cymbals on my old kit, but went sabian this time cos they have so much range
2 bass drums looks tough as, i would love a 2nd bass drum, but as u say not very space efficient lol
It does help. but not to the full effect. Your still going to hear the drums from outside.
The sound rebounds of the circular shape of the cartons. note: half the egg carton.{split in half} not the full package lol.
Sound proofing is extremely difficult to do properly, it really needs either a lot of concrete for the walls or floating floor/room designs..... a combination of both work well but is expensive.
Several cheap things can be done, like hanging blankets from the ceiling. i once knew an engineer tho who had his entertainment room coated in the sound insulating paint that feels like sandpaper (you could throw a beanie on the ceiling and it'd stick)...
and if you could get massive sheets of dynamat to stick to the wall, I'm sure that'd help a fair bit too... double concrete walls are probably one of the best things to have to begin with ($$)
-D
-D
Usually guys that hang blankets and quilts from ceilings and walls are doing it to deaden the sound of the room (e.g. make a drum kit sound less boomy), not necessarily trying to sound proof. Generally acoustic room treatment doesn't have to go hand in hand with sound proofing.
if you're ever building a brick veneer home, use the Bradford style rockwool batts in the studwork as opposed to the typically used fibreglass batts.
They both have similar thermal insulating properties but the rockwool (denser) stacks up better for sound proofing......ultimately double brick would be the way to go but more $$$.
Rockwool is also sometimes used in cavities between floating floors and rooms or as insulation as you already mention.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
