Hi all, im in the process of searching for a set of jap rims for my s2 r33 but with so many choices out there i cant decide,
some of the ones i have been looking at are
rays ce28
work xd9
volk te37
super advan sar v2
etc
post up some of your ideas for the best looking wheels on a gtst along with size/offset and pics if possible
cheers Nick :P
https://www.sau.com.au/forums/topic/268339-best-looking-wheels-on-an-r33-gtst/
white te37's :(
and i also dont mind the look of the white starcorp impuls (although i dont think they are japanese)
na, TE-37's look shite on gts-t's / gtt's, not enough offset to get depth into the spokes. GTR only, same with LM-GT4's
m2 hanbais dt05r in gunmetal. 18x9 +20 all round.
work meister s1 2 or 3 piece. 18x9 & 18x10.
work cr kai - 18x8.5 & 18x9.5.
work xd9 - 18x9 & 18x10.
desmond regamaster - 18x9 +20 all round.
any of those fron the top of my head and sizes close to those will be good as.
No, no they don't. Dezz has a set of them in 18's on his car and they look the shiz! I get all jealous everytime I see them :(
But yeah, +1 for SSR Professor SP1's. Real nice set of rims!
+20 would u have to make a few modifications to fit these offset, this is gtr territory isnt it?.
yer xd9s i like the look of, but i dont mind spending a bit of cash on forged stuff
ther is a user on here named blags who has xd9s on his 33 and the rears have a bit of dish looks mint
The difference between the gtst and the gtr should give you a clue as to what design of wheel would look better.
Because the gtst does not have the "phatness" of the gtr, Wheels with big dish go a long way to enhancing the appeal of the gtst from a looks perspective.
The gtr can get away with far less dish by virtue of its already phat look.
Wheels like meisters and starcorp impulse transform the skinny arsed gtst in to a car with way more street presence.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
