you guys realise the coil pack has a cover on it which it rubber sealed :D
Yeah we do....
But are we gonna trust these seals in a 10yo+ car... I think not. Espesh for the little effort it will take to rag or tape it, a lot less then if they get water in them ayyy?
I just do mine down at the car wash place. Give everything a spray with the engine/tyre cleaner,let it sit for a couple of mins and then spray it off. I used the high pressure rinse setting but only pulled the trigger for the tough bits, the stream from just having it on was enough for most of it. Also, I didn't bother covering anything up, I just avoided the Pod filter. Everything in the engine bay gets wet while driving in wet conditions anyway, I just didn't go crazy with the pressure, just let the soap do it's job.
I hold no reponsabillity for damages occured by followint this procedure, it is given as a guide only.
Ok, ex detailers in put. Run engine to operating temp and turn off, cover exposed pod/s with shopping bag (plastic, not reuseable ones lol). If running no coil cover, place a couple of plastic bags along top of coils to stop them being drown. Wet down whole car ( alot of degreasers will remove wax and polish from panels).
Start spraying you chosen degreaser (Export stuff is basically kero!, better off with Auto Glym or Kenco or another reputable brand), start from the front edge of the bonnet and work back towards windscreen ( good idea to switch climate control off before hand). If you still have the sound absorbing pad on your bonnet, try not to get too much degreaser on there.
Spray engine from top to bottom, inner guards, radiator support and radiator/ac condensor etc. Try not to get too much on exterior paint work.
Let it soak for about 5 mins.
Start hosing from the bonnet down. Be careful of the bonnet liner, they really dont like high pressure and all the crap will drip over your clean engine as it dries.
DO NOT HIT TURBO/EXHAUST/EXHAUST MANIFOLD WITH THE WATER FOR AN EXTENDED TIME WHILE HOT !
Continue rinsing degreaser from engine bay, and also keep exterior panels wet too.
When finished, close bonnet and thoroughly rinse entire car.
Open bonnet, either use air/old chamois/rag to dry any pools of water. Start car a let run for a good 5 mins to let everything dry out. I normally take mine for a drive after just to get the rest of the water out of the chassis rails and engine bay.
Edited by Jamesrb25
exactly, i even used to spray the dirt out of my pod i would leave the car running and if it started to die stop spraying it and give it a little gas its only WATER
then after all that give it a few fist full of revs to burn out any water and away you go as for water seeping into coilpacks its so hot in there if water finds an inlet it will turn to steam before it wets to coils
So while ur POD was ON your intake pipe youd have your car runnign and spray it with high pressure water to remove dirt..... All i could see this doing is pushing it thorugh the filter and ito ur engine to remove it.....
cleaning it doesnt mean pushing it threw ur pod lol....
my vote is degreaser a light rinse, electrics dont like water... known fact... nor do hot turbos or exhausts etc. jamesrb25 obviously knows his shit on this subject... trusting him at this stage... covering pod and going easy!
are you being serious steve
if so then that is definately not good for the car mate....i always take my pod off the car and give it a nice wash, comes up clean and re oil it and put it back on the car making sure that the pod had dried up before re oiling it.....after that it runs like a dream
I use that K&N cleaning and oil pack thing on my filter. Leave it off to dry overnight...
Please people, make sure you cover your coils.
They may have a cover/seals but coolant spraying over my engine managed to wet mine and make me drop cyls. Its worth the extra care.
Edited by ontheranch
Very pleased :)
While car was cold I:
Bag of alarm (pod in box so no need)
Sprayed engine bay down with watered down ct18
let it sit for 5 minutes and carefull pressure hosed it off from a distance
Ragged up any large pools of water
Idled it for 5 mins block lap came home left it cool then sprayed a light coat of silicon spray
Driven it a few times now at running temp and this is how it looks:
that a ground wire kit? nice.
might give it a crack this weekend, got some export but by the sounds of things, paying $1 for it was justified. got coilpack cover off to so i might have to be careful.
Kidafa, where did you get your pod cover? looks good
Made it myself with tinted perspex from Bunnings and some rubber edging from clark rubber. Has a CAI coming of front bar into it aswell.
Have a look in here and follow some of the links in the posts:
http://www.skylinesaustralia.com/forums/Po...hl=cold+air+box
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
