(emailed to me this morning)
“Don't leave a rare WRP10 WRX (only 200 imported into Aus) on display without locking wheel nuts. Actually, probably should have kept it inside and moved a couple of i30s outside for the time you had it.”
For the locals who know how close this is to the police station... and their workshop / hangout.... it is kind of embarrassing.
Edited by Antimatter
https://www.sau.com.au/forums/topic/268627-nunawading-hyundai/
the badge is just behind the front wheel Nick,
nice find Steve, heres an interesting bit of trivia for you all as i work for Subaru.
WRP10 wheels (rays engineering) $1,193 each, yes each! w/o tyres...
oh and we sell lock nut too $114 :D
gee thats gotta suck!
I concur.
However I am torn between the hilarity and awe at the utter boldness, and sick feeling I get when people find it in themselves to do stuff like this.
Insurance or not - I have been on the recieving end such dog acts. It is an awful thing.
Bold, very bold.
However, it's still quite the dog act.
we had the same thing hapen when i was working at another subaru dealer, i dont know if anyone remembers the liberty blitzen, anyway they were a limeted run and they were all bright red, with big expensive wheels.
the salesman who went to move it one morning didnt know what was wrong when he put it in gear but the car wouldnt move... he got out of the car and quickly discovered the problem...
well if anyone finds a set of WRP10 wheels going cheap, be sure to check the data dots. they will be sprayed on the inside of each wheel. :D
Credit where credit is deserved.
Exactly!
Those WRP10 wheels arent the best rims subaru have released though, why would you bother? Try and find one of the late model STi's with the enkei style/multispoke ones that look like blitz technospeeds
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
