  • Replies 79
So you are entering in the dyno comp then paul..... Hmmm maybe i might have to enter ole Sly then aswell ...well if you guys are rockin up to move your cars past all the other bloody show cars AND THEN onto the dyno pack dyno i will prob see you on the dyno hmmmm say about 2pm, mine will prob be on there then at 4. That dyno is really accurate and all but honestly why would it be allowed in show use with 40 cars in line, to swap a s15 silvia to a 180 sx today timed a bit more than 25 mins, dunno whether or not they where takin it easy but the crowd didn't like it and half went away. I have no doubt these dyno packs are awesome for reading but as i have now seen are quite time consuming, plus possibilities of wheels getting damaged and not too mentioned not being put on tight enough.... if you had changed 200 or so wheels in one day i know i couldn't be stuffed tightening them all up properly *mental note to you all, never let me tighten your wheels*:( :bahaha:
Good showing everybody.
Was nice to put a few more faces to names (or nicknames). Congrats Paul on not blowing up your engine and bettering your dyno with a 431HP. Sensational. Shirts are good too. Quite a few Skylines which is great, couple of lovely GTRs....mmm...
Originally posted by 25GTT
That dyno is really accurate and all but honestly why would it be allowed in show use with 40 cars in line, to swap a s15 silvia to a 180 sx today timed a bit more than 25 mins, dunno whether or not they where takin it easy but the crowd didn't like it and half went away. I have no doubt these dyno packs are awesome for reading but as i have now seen are quite time consuming, plus possibilities of wheels getting damaged and not too mentioned not being put on tight enough.... if you had changed 200 or so wheels in one day i know i couldn't be stuffed tightening them all up properly *mental note to you all, never let me tighten your wheels*:P :bahaha:
For starters we use torque wrenches on all wheel nuts, every single nut across the 34 cars we dyno'ed over 2 days have their nuts done up to the same safe level. We are extremely mindful of such concerns about wheel damage etc.. Why do you think we dont use rattle guns? We've got em, dont use em on street cars.
Secondly your time concerns, yes there were a few cars that took longer than others, the 4wds obviously. As far as whether the crowd liked it or not, we didnt give a shit. We were doing our job as quickly and reliably as possible, or do you want us to drop wheels on their face on bitumen? A GTR today had to be taken off the dyno after being completely bolted up due to its body kit being too wide and the risk of damage to the car was considered too high.
But i guess you think we should have run it anyway, cracked the sideskirt off, just to please the crowd, so we didnt waste any of their precious minutes.
Red17
Red17
Points taken red 17, in no way did i say that you guys did a bad job at all, in my post i also said the dyno has been praised as being quite an accurate dyno, however we must keep in mind that th show wouldn't be the show without the crowd. you guys did do a fantastic job and i have no doubt that you guys have excelled more than what most people have done or what i could do, changing those wheels would be annoying and for you guys to stick with it all day was well done.
My point however is that although the dyno is accurate the problems with it is time consumption and now as shown the problem with putting cars on with wider body kits, of course i would rather the GTR not go on there but this is an advantage that a normal dyno would have had. It's unfortunate that we can't say stuff the crowd as half of the SAU guys on here are "the crowd" we have to give a shit about them as they are the ones that have paid $15 entry to look at cars and without the crowd the show is not a show.
Anyways - you did a good job dude and now that you mention it I am bloody glad no rattle guns were used especially with what happened to one of my old mags a few years back!
I think Ivan and the APA guys did a great job, yes it does take a long time, but they worked there asses off, and if people weren't so precious about having the cars shown on Sunday arvo then they would have done even more cars.
Even the DD dyno's won't necessarily be able to handle really slammed cars:(
BTW, special thanks to Ivan for not blowing up my car:D
Thanks for the praise fellaz, i should apologise for my tone in my original post. Id just gotten in from PAS and the APA team had been severely chastised by a certain person on a certain trade stand for quote "running a dyno comp nobody ****ing wants".
So suffice to say I was not in a good mood.
Red17
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
