im not quite sure why you guys want a speedo that goes to 300kph. i dont think theres a track in aus with a long enough straight to reach that speed in a stag. id think 250kph would be more than enough for a stag here.
I would have made it 320km/hr but it would be too crowded. The stock 180 speedo is ridiculous so what to choose? 240 or 280 would be enough in most circumstances but 300 should suit most everybody. Its not economical to make a range of different maxima so I settled on 300.
Sigh, I need to remember to look at this while at home so I can actually see the pics!
Got a part number for the Jaycar adjuster?
Speedo correcter Mk II KC-5435 (plus box HB 6015)
  • 3 weeks later...
Probably easier to get the kit from Jaycar but if you do find someone who can reprogram you speedo head let others know as apparently it takes a while to work it out but once done can be easily replicated.
  • 8 months later...
Ok reviving an old thread as there are issues with the site and I can't post in the for sale section. I have bought three Jaycar speedo corrector kits as they are being discontinued and I am able to offer a 300km/hr speedo kit consisting of a dial face, the Jaycar spedo correction kit (requires assembly/soldering) and the isolating washer mentioned in the simple wiring instructions I have found to make it all work for AU$99 posted anywhere in Australia.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
