Hi Guys..
Wanted to know where is a place to get my Rear Gaurds lipped
Car is a Series 2 R33 GTS-T
I've msg'd a few people here but the soure they gave me is NOR
Tried G Grieves... n they said they're too busy wif Insurance work.. and Autoworks in Welshpool but they haven't gotten back 2 me.
Yeh I mainly after SOR places
Thanks
Sesar
https://www.sau.com.au/forums/topic/269083-lipping-rear-gaurds/
Hi Guys..
Thanks
Sesar
Dentcraft they come to you
If I remember $150 real nice job
Will Dentcraft pump out the Gaurds a bit?? incase i wanna put wider tyres on it in the future?
No all they do is heat up the guards and tap it softly for about 20 mins
sounds strange I know but works real good.....no sign it has been done externally
My rears were scraping at every bump and after lipping never had a problem again
but as my wife usually says....no pumping
I think they are in the phone book, but I have a card at work so I will have look tomorrow
and let you know
and let you know
Ok Thanks.. tha would b helpfull
What Tyres and specs do u have on ur Rears n how low is it???
Mine u can just fit ur pinky winky finger.. in the gaurds..
It's 265/35/18 wif offset of 32 on 9.5" rims
lol with a jack sounds bush styles too.
So does this; adjusting the cars coilovers to sit super low, then find some heavy people to sit in the back
Back on topic, most places don't guarantee that it wont crack the paint, they use a heat gun to heat the paint and panel cracking still can occur. Around $50 a corner is what most places charge using a proper guard roller, not worth wasting your time with steel poles, jacks, or fat people.
Stuart from Dentcraft did mine. Got the 2 rear guards rolled.
He will jack your car up.
Take the wheels off.
Bolt on a roller to your hub.
Use like a really fkn hot hair-dryer to heat the guards/paint.
Roll them, tap them with a soft hammer/mallet till they're lipped.
If your paint is original and in good condition, you shouldn't have a problem with the paint cracking.
Paint is Original and is in Good condition :-)
Do u guys know where i can buy some C Spanners or burrow some.. I need to raise the front end cuz u really can't really roll
the front end or will they do them as well.. None of my friends have C Spanners for my Coilovers..
-SeS
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
