hey alll
i have a red top nics rb20 in my all original hr31 that was running perfect...
but now if i try to slowlly bring the revs up it farts and coughs around alot..
was thinking tps so i swapped it out and changed nothing..
when i first put the motor in the car it ran fine... now just recentlly its gone up shit creek..
any one have ideas??
is this a common thing?
was thinking maybe afm?
cheeers for any help
tom
:happy:
https://www.sau.com.au/forums/topic/269506-red-top-rb20/
alright sweet
i have 3 spare sets of coil packs and a spare cas and spare tps..
already tried swapping over the tps but that did nothing...
il try cas next..
its a nics red top..
cheers for your help guys :whistling:
tom
https://www.sau.com.au/forums/topic/269506-red-top-rb20/#findComment-4592431
i wouldnt bother with a cas..
if it was the cas it wouldnt run. its just an eletronic pick up.. either it picks it up or it doesnt.. simple as it. its not like a coil where it can sorta pick it up enough to run.. doesnt work like that. either it has a signal or not
coil packs i look at.. with a weak spark, its easy to blow it out if u induce enough air
might be afms also.. does it happen under load or just rpm??? example.. foot down to the redline it farts n coughs.. or ur at the redline without having ur foot flat.. just enough throttle to keep it there and still does it..?
https://www.sau.com.au/forums/topic/269506-red-top-rb20/#findComment-4593096
what sensor would cause this.???
afm maybe??
iv tryed swapping over a set of coilpacks but that didnt do nothing...
i cant justify going out and finding a red top rb20 afm if it isnt needed...
as anyone would know parts for these donks are hard to come bye
cheeers guys
https://www.sau.com.au/forums/topic/269506-red-top-rb20/#findComment-4601387
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
