hi guys
Anyone got a pic of a r32 gtst tyre placard / sticker so I can make up one and print it out. need one for regency!!!
THX!!!!
you can get them from importers, synergy usually has them in stock for $15 i think. saves you mucking around.
mine lists off every tyre option gtr's had with about 4 diff sizes, not sure what size they ment to read on there as there is a few 16inch sizes mentioned.
it also has 17's which only the vspec got i believe, so not sure why mine says it.
why u crazy fools feel a need to go 1 inch bigger, by my calculation its 5.555555555556 % bigger than a 18inch. not really noticable in my book.
go wider, getting 4 275's tyres are where its at :)
can they?
Yes, they can.
Its pretty frigging stupid to forge a tyre placard. It doesn't take a genius to know that the max legal diameter for rims is +2 inches above the factory standard, which is 16" on r32's.
Not only will you get a defect for it, you'll get some kind of fine for forging documents pertaining to roadworthiness.
-D
LOL
Not only do cops read these boards but after speaking to Nightcrawler the other night, some of you need to be aware that lawyers employed by auto businesses also read here.....so careful what you think you can say about a business, regardless of whether you think you can substantiate your allegations!
Inpectors at Regency weren't born yesterday either.......be very certain that if your vehicle displays any forged plates or placards of any description, your vehicle will be detained while police attend and pull you aside for a little interogation.
yet another reason why skylines shouldnt be owned by children
hope someone brings in the 25 year old min rule for turbo owners sometime soon. help make my insurance premiums go down...
-D
-D
if youre over 25 insurance is cheap enough as it is... how much cheaper do you expect it to be??
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
