  • Replies 141
We went down to Haunted Hills for a look today...
When we left, Ryan had set the fastest time overall at the Haunted Hills Hill Climb.
and at a rough guess it looked like Thompson and Newton were still looking good for taking out the overall title...
Haven't heard any official results as yet...
stupid website doesn't work for crap
Wicked work all round guys espec to Adz and Scottsman on the win! Def looks like the SAU guys are were up there going by the results of the haunted hills runs on the duttonrally website. Will be interesting to see where frysie and mick ended up in the results.
I'm feeling quite busted this morning. Huge well done to Ryan, getting the fastest time all day at Haunted Hills, and on the DECA pan at morwell. Also for giving vin a run for his money in his factory backed Sti.
No cones and Jebus, hats off to you kids for taking out the overall, well done!!!
Pics will be a few days, too much on to get them out stright away, but there are some corkers, Bris entry into the first gate at Lang Lang? "I'll just give it a Scandinavian flick", i've heard that before mate, first DECA?
Thanks to everyone i caught up with, you all helped make it the fun weekend t was.
Great work by those white SAU cars for your reults....and of course Russ for letting me punt his car. Its a good thing 1.55bar for 3 days :)
Snowie and Master Paris, i am guessing the white car was a better back up then old Golgo :woot:
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
