Hey guys thought i would start a new thread on my car so i can ask all questions/suggestions/comments on one thread.
People interested can follow my progress as i go..
Car is R33 S2.
Mods: (current)
-Split fire coil pack
-Full exhaust
-K&N filter
-Apexi Cooler
-Mines ECU (non programmable)-factory tuned to 12psi-14psi
-Turbo tech manual boost controller
-Greddy blow off
Made 207.8KW at wheels with stock turbo at 12 psi. Since then i ran 14 psi for a bit and blew the turbo. Upgrade here i come!!! Here is dyno chart for those interested:
Installing:
Gt3040 AKA Garrett 3082r(top mount), manifold, external wastegate (40mm)
Aim is 240kw at wheels.-Suggestions? is it possible with this set up running 14psi on this turbo?
Future: Aim 270kw
Power FC, fuel pump, injectors (in no particular order). Suggestions please?
https://www.sau.com.au/forums/topic/270210-modifying-r33-s2-in-progress/
definitely not safe without a bigger fuel pump. that should be much higher on the priority list..
next thing is injectors maxing out... may need adjustable fuel pressure regulator/ new larger injectors to put more fuel into the engine to mix with the larger amount of air pumped in from the bigger turbo.
next thing is afm will be close to its max now, i dont think it would hold up to 240rwkw... so probably need a z32.
Thank you for your inputs.
Its clear that i must get a FUEL PUMP so ill be looking for a 040 pump from now on. Hopefully i find one soon so i can install it while the turbo is getting done, at the same time.
As for injectors, im not sure what to look for? What brand is good enough?
hi
for that turbo you will need
turbo
manifold
external wastegate
exhaust dump pipe changes
powerfc
boost control kit (or elec boost controller)
fuel pump (nismo or 040)
injectors (550cc or GTR might be ok with resistor pack, 550cc is probably easier)
z32 airflow meter
budget around $11k supplied, installed and tuned, no problems with 270rwkw
youll have problems with traction however
the cheaper solution? but a 2nd hand R33 GTST turbo for $300 and be happy with 200rwkw
hi
turbo
manifold
external wastegate
powerfc
z32 airflow meter
:D
you might find the 3040 will peak near 290rwkw ish
so its probably too much power for your requirements and budget
as you climb the power band, the cost $ per killowatt expotentially increases
ive had 200rwkw for about 5 years now and i have no issues with most cars on the street
i think ive had probably 2 vl;s and 1 or 2 v8s beat me properly
so you dont need 280rwkw to be quick on the street
for example if you got a hiflow or 2nd hand stocker and
spent some $ - maybe $2k on suspension youll make the quicker and handle heaps better
hi
turbo
manifold
external wastegate
powerfc
z32 airflow meter
the cheaper solution? buy a 2nd hand R33 GTST turbo for $300 and be happy with 200rwkw
Okay lets see your list:
I have the following:
turbo-YES
manifold-YES
external wastegate-YES
exhaust dump pipe changes-YES
boost control kit (or elec boost controller)-YES
fuel pump (nismo or 040)-YES, got one today just need to pick it up.
New clutch-YES.
The following i will need:
injectors (550cc or GTR might be ok with resistor pack, 550cc is probably easier)-NO-not yet, looking
z32 airflow meter-Not yet, have to do more research to understand what it does.
powerfc-NOT YET-probably last thing because of tune.
I'm confused, people say you can run 240rwk on a hi flow on 17psi but you cant run 14psi on this turbo with out injectors and pump and z32 airflow meter? Or did i misunderstand that?
My initial plan was to go with these mods: (to achieve 240kw)
-Full exhaust
-K&N filter
-Apexi Cooler
-Greddy blow off
-Gt3040 AKA Garrett 3082r(top mount), manifold, external wastegate (40mm)
-040 Fuel pump
-Clutch when this one goes
Basically i was hoping with that set up i would be able to run 240kw on 14 psi, and have room for improvement when i get bored of 240kw.
Yes you are spot on, i had the same experience. But i got raped by every skyline r33 i tried (2). So i they are fast in the same car, i wouldn't mind being a bit quicker too. But yea you are right, to get the upgrades now, its big bucks.
you cant tune the mines computer, all you can do is plonk it on the dyno
and hope the afrs are OK and it runs ok, given you are changing AFMS and injectors, its unlikely
it probably wont even idle - so unless you can find a shop to remap the mines ecu (try dr drift)
your stuck with a probably unsafe tune / unstable or youll have to replace the ecu
your better off changing injectors, AFM and ECU all at once
and getting it tuned once for the most safest power you can make
then use your brains to control the power or turn the boost down
doing a complete tune on one level of PSI, then months later
doing it again on another level of PSI is stupid
or turning up the boost later and hoping for the best (ie, without retune) is also stupid
i dont see why you need a Z32 or injectors..
Im getting 242rwkw with:
Highflow turbo
Mines ECU + Safc
Exhaust
Cooler
Pod
Walbro fuel pump
Shard adj Fuel Reg
Boost controller on 1 bar boost on safe tune..
Hmmmm, interesting. I see you have Shard adj Fuel Reg, do i need it on a big turbo, in you opinion?
and just how did you manage to overcome an ~ 80kw difference?
schumacher, is that you? :blush:
(seriously though, i would like to know)
Depends if you want more power later on..
I got use to the power in 2 months.. now i want more..
If you JUST want 240rwkw i say go highflow.. its cheaper..
Oh btw.. Dr Drift did tune my Mines ECU.. =]
Oh and if u get EPA'd, ull be taking the turbo out cos its aftermarket and it looks bigger..
I had no problems with the highflow :blush:
I nearly went for hi flow but thought of future wants and needs so i opted for bigger turbo.
So dr drift tuned your ECU, what the rough price for that job?
As for EPA, i know. hehe o well we all take risks.
    • Plazmaman 76mm Pro Series, done. Data to back it up, I posted up somewhere here a few years back
    • So.....wire it up appropriately. You can't use the resister pack with those injectors anyway.
    • that’s the thing i’m on ID1050s and haltech not getting power due to the injector resistor
    • ahh okay cheers, i was thinking of just going for the m073, think m079 would be way too overkill considering they are same size.
    • My first car was a HG. I'm very familiar with them. A mild cam upgrade is a good idea. The 186 is a very flexible engine - meaning it has good torque from down low. You can give up a little torque down low for quite a lot more excitement in the mid range, and a bit more up top - but they are not exactly a rev monster. You need to upgrade valve springs at the minimum. For a bigger cam, you'd want to make sure it wasn't still running the original fibre cam gear. That would be unlikely, given that most of them shat themselves in the 70s and 80s, but still within the realms of possibility. Metal cam gear required. Carbies are a huge issue. The classic upgrade was always a Holley 350, which works, but is usually pretty bad for fuel consumption. The 186S had a 2 barrel Stromberg on it that was very similar to the one on the 253, and is a reasonable thing if you can find one, and find someone to help you get it set up (which is the same issue with setting up a 350 to work nice). The more classic upgrade was twin sidedraught CD type carbs, or triples of same, or triple Webers. The XU-1 triple Webers being the best example. You can still buy all this stuff new, I think, but it's a lot of coin to drop. And then the people able to set them up are getting fewer and further in between. There's still some, but it used to be everyone's** dad and uncle could do it. **Not everyone's! But a lot. All in all, I wouldn't get too carried away with the engine. Anything you do to it without a full rebuild for power and revs will only make it slightly faster. I am all in favour of a complete teardown rebuild, with nice rods and pistons, 10 or 10.5:1 compression, and a clean port job with at least a big enough cam to run 98 with that compression, if not bigger. And if I did that to a dirty old red motor, I'd want to inject it too, which I'd struggle to fight against the devil on my shoulder that would argue for ITBs and trumpets. But the bills would start to mount up, and it will still never make stupid power. OK, a few people still know how to build absolutely mental red motors, courtesy of the work that went into HQ racing and modern knowledge being applied. But even a 300HP red motor is no match for an RB20 with a TD06. So you have to decide what it's worth to you. I'd just put a set of 6>2>1 extractors, a 2.5" exhaust and an electronic ignition conversion/dizzy on it and just run the old girl like the fairly slow old girl that she really is.
