Anyone Run Their R35 At Eastern Creek (circuit)?
Can anyone who's tracked their car fill me in on what levels to reduce the fluids down to? Manual says engine oil to 10 mm below H mark. Powersteering to R mark. But no mention of the brake fluid however on a separate thread about servicing costs there was an item listed which was reduce brake fluid level at the pre race inspection.
Cheers
  • Replies 47
Cheers
I've done 10 track days in about 4 months and never once reduced fluid levels, no adverse issues experienced thus far. What's the reasoning behind it all? Sounds like BS to me. I guess some fluids might get hot/expand with some overflow? I've never seen it happen if that is of any help.
Thanks for that. I guess thats what they're getting at. Other than overflow perhaps it pays not to have engine overfull to avoid aeration of oil maybe from crank windage? And only leakage to be overly concerned about would be brake fluid anyway.... A bit of a mess around my PS filler isnt going to bother me too much even if it was to occur!
Out of interest have you bled the brakes afterwards? Used the standard fluid? What alternatives has anyone used?
Cheers
David
Cheers
David
I've neve had a PS fluid overflow yet, or any other fluids. With brake fluid, i always bleed after a track day (or just before). I think the OEM fluid is about $160 a litre, however i switched to Brembo LCF 600 which i is about $50/bottle (500ml). I completely flushed the OEM fluid out when i changed the rotors and pads. I am not paying $160/litre for brake fluid, given how much i am going to use over the next year.
Edited by LSX-438
what mods are done to the donutking gtr? i wonder what a factory r35 would run at EC...
Dunno about the donut king car but a stocker R35 seems to be good for a 1:45 or thereabouts at EC. I am sure better in the hands of a pro.
haha Kel's been in a crash in that car. Pete's car not Tony's one I reckon.
it was built to Targa S1 rules..which basically means stock. they can change ECU, shocks and springs and add safety gear. but it was running on slicks (on 19s I think).....but these days the semis are pretty close to full slicks, especially in the hard compounds you run on a heavy car
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
