Finally results are in.
She punched out 200.2 ATW on 12 psi (although spiking to 12.8) Not bad. But useless.
As soon as i took it out on the street off the dyno and gave it some... Rattling noise. Ping im sure. The 'tuner' was with me at the time, and looked concerned when i stated hey its f**king pinging hard.. he wound back the boost a little and f**ked with the timing.
Still did it at around 11.8psi. He stated you need a decent intercooler... Drove it tonight briefly on the high setting and it didnt ping (very cold out tonight), but it comes on boost in an unstable manner. the dyno readout is pretty wobbly and has a dip higher in the revs. Ill post this when i can. Looks like shit to me. With the standard solenoid grounded permanently it pulled 182kW ATF 9psi and a nice flat curve.. With the Eboost on 12psi its wobbly and looks like shit.
The boost controller is a new Turbosmart EBoost Street. Ive been reading the manuals and its states various options regarding gate pressure and sensitivity. Im sure these could be improved as it spikes considerably. I thought these f**king electronic things didnt spike once set properly.
Seems i now have little to no faith in his abilities or advise so im forced to have it retuned by someone who is trustworthy because i cannot comfortably drive it again without freaking out. Its now set back to setting one with runs around 9psi.
Can anyone please a reputable tuner in Sydney??? I dont care what it costs as long as they know skylines!!! Desperately need some decent advise i dunno who to listen to now
This sucks as this car was absolutely perfect prior and its disappointing to be honest. Its impressed everyone whose worked on it... Im now contemplating ripping it all out and replacing it with the factory setup as before running high mode constantly... Atleast i could rev it and not worry about destroying the motor.... Surely i could run 10-11 psi with a r34 SMIC without troubles??
Current mods
R34 SMIC
3 inch Nismo exhaust
JJR Split Dump/Front
K&N High Flow Panel
Turbosmart EBoost Street....
Cheers,
Matt
https://www.sau.com.au/forums/topic/270319-r33-gts25t/
does it have an aftermarket ecu or are they just advancing the timing via the CAS?
Standard ecu. I wouldnt have a clue as to what you would do if you were adjusting timing (im mechanically impaired). I heard him mumble it, open the bonnet and adjust something at the front of the motor?
https://www.sau.com.au/forums/topic/270319-r33-gts25t/#findComment-4598610
You pulled 200kw@wheels on the stock ECU and a side mount :blush:
The stock ECU should be dumping bulk fuel, how the hell is it pinging?
Adjusting the timing via the CAS is pretty bloody dodgy.
Edited by PM-R33
https://www.sau.com.au/forums/topic/270319-r33-gts25t/#findComment-4598623
+1
You need a decent fmic or a bigger side mount, also what are your plug gaps, at that boost level should be 0.8 or 0.9mm
https://www.sau.com.au/forums/topic/270319-r33-gts25t/#findComment-4598630
no need to reduce the plug gaps, if your coils are good you can (and i do) run 1.1mm all day every day with any sort of power the stock turbo can give you.
To a point of course, i hit 18psi with my standard turbo and it was breaking down, i now have a hi flow and any more than .85bar and it starts to break down.
https://www.sau.com.au/forums/topic/270319-r33-gts25t/#findComment-4598640
ive never heard pinging before. it was an obvious metallic rattling at revs under load. But the AFR's showed at high revs around 10.5 : 1. Its got me f**ked i just dont understand it enough to get my head around whats happening.
https://www.sau.com.au/forums/topic/270319-r33-gts25t/#findComment-4598653
People are running in excess of 200AWKW with an R34 smic - that's not the problem. You need some way of tuning the motor and just playing with the cas doesn't count.
If you can't afford a Vipec get an SAFC and an SITC and get them tuned on a dyno.
Contact Anthony (Guilt Toy) for a tune and the lowdown on your options (may be others in your area but I wouldn't know).
https://www.sau.com.au/forums/topic/270319-r33-gts25t/#findComment-4598886
Another point is that you should never hear pinging with a standard r33 ecu as when ever the knock sensors pick up knocking (usually it is very conservative) it will retard it.
the sound of knocking, its fairly loud? could be heard over the motor revving? this was
https://www.sau.com.au/forums/topic/270319-r33-gts25t/#findComment-4598993
is the engine light flashing when the "noise" occurs? if its detonation, and you can hear it whilst driving, inside the car, surely the engine light will be flashing.
its not something silly like being able to hear the EBC solenoid ?
if its detonating, and the engine light is not flashing, maybe check the ecu and see if it has been attacked. maybe its been fiddled with
is you rev limiter at 6800 or 6900 or what ever the stock limter is? what about speed limiter?
i know my car a few year back on the std ecu, anything over 10 psi, Rich & retard would chime in, and it would run like a fat kid through sand.
https://www.sau.com.au/forums/topic/270319-r33-gts25t/#findComment-4598995
I didnt notice the engine light. I generally notice and hear every noise and rattle. i dont think ive ever revved it to the limiter. it revved to nearly 7 on the dyno but i didnt hear a limiter. The rattle noise also appeared a little lower in the revs around 4-5 k...
It shows on dyno sheet AFR running down to mid 10's which is apparently rich as hell. my piss weak understanding tells me it shouldnt knock if thats the case? One thing is certain on high mode last night it spikes up to atleast 13 or more. On the low setting it doesnt spike at all. After reading the EBC manual i think i can adjust this with gate pressure etc so it doesnt come on boost as quick etc??
Ill pay anyone who is genuinly capable in there trade and has a good knowledge of skylines. Im tired of pretenders, as this EBC wasnt cheap including the dyno run/tune which was useless as tits on a bull.... what good is 200 ATW if you cant use it safely
https://www.sau.com.au/forums/topic/270319-r33-gts25t/#findComment-4599005
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
