Finally results are in.
She punched out 200.2 ATW on 12 psi (although spiking to 12.8) Not bad. But useless.
As soon as i took it out on the street off the dyno and gave it some... Rattling noise. Ping im sure. The 'tuner' was with me at the time, and looked concerned when i stated hey its f**king pinging hard.. he wound back the boost a little and f**ked with the timing.
Still did it at around 11.8psi. He stated you need a decent intercooler... Drove it tonight briefly on the high setting and it didnt ping (very cold out tonight), but it comes on boost in an unstable manner. the dyno readout is pretty wobbly and has a dip higher in the revs. Ill post this when i can. Looks like shit to me. With the standard solenoid grounded permanently it pulled 182kW ATF 9psi and a nice flat curve.. With the Eboost on 12psi its wobbly and looks like shit.
The boost controller is a new Turbosmart EBoost Street. Ive been reading the manuals and its states various options regarding gate pressure and sensitivity. Im sure these could be improved as it spikes considerably. I thought these f**king electronic things didnt spike once set properly.
Seems i now have little to no faith in his abilities or advise so im forced to have it retuned by someone who is trustworthy because i cannot comfortably drive it again without freaking out. Its now set back to setting one with runs around 9psi.
Can anyone please a reputable tuner in Sydney??? I dont care what it costs as long as they know skylines!!! Desperately need some decent advise i dunno who to listen to now
This sucks as this car was absolutely perfect prior and its disappointing to be honest. Its impressed everyone whose worked on it... Im now contemplating ripping it all out and replacing it with the factory setup as before running high mode constantly... Atleast i could rev it and not worry about destroying the motor.... Surely i could run 10-11 psi with a r34 SMIC without troubles??
Current mods
R34 SMIC
3 inch Nismo exhaust
JJR Split Dump/Front
K&N High Flow Panel
Turbosmart EBoost Street....
Cheers,
Matt
https://www.sau.com.au/forums/topic/270319-r33-gts25t/
does it have an aftermarket ecu or are they just advancing the timing via the CAS?
Standard ecu. I wouldnt have a clue as to what you would do if you were adjusting timing (im mechanically impaired). I heard him mumble it, open the bonnet and adjust something at the front of the motor?
https://www.sau.com.au/forums/topic/270319-r33-gts25t/#findComment-4598610
You pulled 200kw@wheels on the stock ECU and a side mount :blush:
The stock ECU should be dumping bulk fuel, how the hell is it pinging?
Adjusting the timing via the CAS is pretty bloody dodgy.
Edited by PM-R33
https://www.sau.com.au/forums/topic/270319-r33-gts25t/#findComment-4598623
+1
You need a decent fmic or a bigger side mount, also what are your plug gaps, at that boost level should be 0.8 or 0.9mm
https://www.sau.com.au/forums/topic/270319-r33-gts25t/#findComment-4598630
no need to reduce the plug gaps, if your coils are good you can (and i do) run 1.1mm all day every day with any sort of power the stock turbo can give you.
To a point of course, i hit 18psi with my standard turbo and it was breaking down, i now have a hi flow and any more than .85bar and it starts to break down.
https://www.sau.com.au/forums/topic/270319-r33-gts25t/#findComment-4598640
ive never heard pinging before. it was an obvious metallic rattling at revs under load. But the AFR's showed at high revs around 10.5 : 1. Its got me f**ked i just dont understand it enough to get my head around whats happening.
https://www.sau.com.au/forums/topic/270319-r33-gts25t/#findComment-4598653
People are running in excess of 200AWKW with an R34 smic - that's not the problem. You need some way of tuning the motor and just playing with the cas doesn't count.
If you can't afford a Vipec get an SAFC and an SITC and get them tuned on a dyno.
Contact Anthony (Guilt Toy) for a tune and the lowdown on your options (may be others in your area but I wouldn't know).
https://www.sau.com.au/forums/topic/270319-r33-gts25t/#findComment-4598886
Another point is that you should never hear pinging with a standard r33 ecu as when ever the knock sensors pick up knocking (usually it is very conservative) it will retard it.
the sound of knocking, its fairly loud? could be heard over the motor revving? this was
https://www.sau.com.au/forums/topic/270319-r33-gts25t/#findComment-4598993
is the engine light flashing when the "noise" occurs? if its detonation, and you can hear it whilst driving, inside the car, surely the engine light will be flashing.
its not something silly like being able to hear the EBC solenoid ?
if its detonating, and the engine light is not flashing, maybe check the ecu and see if it has been attacked. maybe its been fiddled with
is you rev limiter at 6800 or 6900 or what ever the stock limter is? what about speed limiter?
i know my car a few year back on the std ecu, anything over 10 psi, Rich & retard would chime in, and it would run like a fat kid through sand.
https://www.sau.com.au/forums/topic/270319-r33-gts25t/#findComment-4598995
I didnt notice the engine light. I generally notice and hear every noise and rattle. i dont think ive ever revved it to the limiter. it revved to nearly 7 on the dyno but i didnt hear a limiter. The rattle noise also appeared a little lower in the revs around 4-5 k...
It shows on dyno sheet AFR running down to mid 10's which is apparently rich as hell. my piss weak understanding tells me it shouldnt knock if thats the case? One thing is certain on high mode last night it spikes up to atleast 13 or more. On the low setting it doesnt spike at all. After reading the EBC manual i think i can adjust this with gate pressure etc so it doesnt come on boost as quick etc??
Ill pay anyone who is genuinly capable in there trade and has a good knowledge of skylines. Im tired of pretenders, as this EBC wasnt cheap including the dyno run/tune which was useless as tits on a bull.... what good is 200 ATW if you cant use it safely
https://www.sau.com.au/forums/topic/270319-r33-gts25t/#findComment-4599005
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
