Hey Folks,
Quick question, is anyone here from, or know much about Port Noarlunga? My team is racing powerboats there in a few weeks time in a Victoria vs SA challenge, just wondering if anyone could tell me anything about the beach? (I'm from one of the Vic teams obviously)
Cheers,
Nick
Hi Nick, as you are an interstater I will leave this post up for a couple of days, but normally non-car-related stuff is not tolerated as new threads in the SA section - I tell everyone to take it to the Wasteland. We had the forum constanly filling up with the most rubbish threads, so I put a stop to it.
I will leave the thread here until Wednesday.
u after surf for surfing, or just what the water conditions are generally like around port norlunga? im not sure so i will give a quick answer for both lol
surfing wise, you want get a decent wave there unless its 40 knot onshore. so go 2 minutes either way, one side has christies which has some great heavy beach breaks, gets real packed tho. other side has southport, another beack break and if you keep wandering down the cost you will get about 15 other reef breaks, generally always smallish, but on stormies gets prob the best wave on the coast down at seaford.
boat wise, this time of year ur lucky if its not several meters out there. always bumpy and cold. port norlunga has a massive reef running in line with the beach about 400 meters out. water depth is a sheer drop off after that, plenty of seals, sharks and the like.
where is this contest? i havent seen any flyers or anything for it wouldnt mind checkin it out!
Nightcrawler - Thanks for that, I appreciate the help. Sorry for breaking the etiquette!
Rhys - Thanks for that, not really after surf conditions, after racing in 10ft break yesterday i'm kinda glad it's glassy, don't know if my body would cope with another beating! The racing is part of the Surf Lifesaving competition program, racing the rescue ducks. I'm not suprised you haven't heard about it, it doesn't get much exposure, but it's a growing sport. If you're keen on checking it out, head down to Port N on the 6th and 7th of June. 6th is the Vic v SA challenge, and the Sunday is regular competition.
pretty sure the surf club runs behind the reef, which is damn near flat/choppy to less then a meter surf unless its stormy, then expect 1-3 meter waves depending on tides. i have photos of surf breaking on the jetty during a storm with waves about 4-5 meters up
I'll pm you a photo later today from past, and one from today.. I'm heading past it today..lol
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
