hey guys,
Just wondering if anyone can give me the details of some where that supplies paint to suit my skyline, i have the name of the paint and the code just stuck as to where i can buy it. i have all the tools just cannot find the paint.
Any help would be appreciated
:P
https://www.sau.com.au/forums/topic/270711-car-paints/
oh ok do you know how long they take to make them up and if the quality is any good? Iam guessing all i need is the paint name and code? Do all supercheaps make up paint or just a select few? Thanks for that info Gaz.
Edited by phenline
https://www.sau.com.au/forums/topic/270711-car-paints/#findComment-4603673
auto1 mixes paint.
also, theres a place called auto power or auto paint, in balcatta, on the corner opposite near geddes st that mix paint pretty cheap.. and is a specialty car paint shop too.
That balcatta one is great. They dont just go on the code, they compare your actual car and it usually ends up being slightly different. They even put the paint into a spray can for you for those real backyard spec paint jobs. Nice people too.
https://www.sau.com.au/forums/topic/270711-car-paints/#findComment-4605454
There are a few paint places in perth as far as paint goes its all the same quality.. for the actual stores dont know about the quality for supa cheap.. and auto1
TOTAL PAINT SUPPLIES (9248 8812)
Unit 2/19 Vale Street, Malaga
(GREAT FOR SMALL THINGS - Car filler - Mixing things ect..)
APC (9272 7023)
Unit 1/30 king Street, Bayswater,
BEST FOR PAINT it cost me $695 for all paint and thinners to pait a whole car and kit.. (4-1Primer,5ltr of my silver,2-1 clear, 20ltr thinners, 4ltr prepsol)
Premier Paint's
Beach rd.. malaga near NEW bunnings
NOT CHEAP BUT GREAT QUALITY
https://www.sau.com.au/forums/topic/270711-car-paints/#findComment-4607057
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
