redline 10w-40, $168 for 3.8ltr
i would not follow what the manual says as we are in Australia and not japan so the oil preforms differently. You will need a thicker oil than 5w-30 because you will get unwanted engine wear over time. Best weight is 10w-60
the only reason i have 10w-40 in my car is because its only one 453km ...... literally. don't go thinner than this.
https://www.sau.com.au/forums/topic/270784-oil/#findComment-4623241
redline Lightweight shockproof has probity saved my gearbox. I dont care is cost more than gold my gearbox stopped being clunky and made it feel new again :)
ended up making every single part in my car that needs oil being redline oil and dont forget the coolant :)
https://www.sau.com.au/forums/topic/270784-oil/#findComment-4623441
  • 1 month later...
The reason for not using a thin oil on an older engine is because of the engine bearings ...
if you use a thinner oil it increases the possibility of you spinning a bearing
just like in a used differential it is unwise to change diff oil with old bearings ... as when you add fresh oil with old bearings they fail
https://www.sau.com.au/forums/topic/270784-oil/#findComment-4732459
whats every ones thoughts on using penrite hpr 15 0nce i flush my oil? also iv been told if i use the shorter z170 filter instead of the longer z115 (both do fit the z115 is the standard recomendation for a c210 the z170 for the r30) it will boost my oil pressure slightly witch makes sence to me but is this a bad idea in an engine 28 yrs old with almost 170 000 km on the clock? any ideas would be greatly apreciated
https://www.sau.com.au/forums/topic/270784-oil/#findComment-4733715
where when n how much do i need to buy
i been told to use penrite hpr 15 but im gona flush it with crappy gtx first
http://www.skylinesaustralia.com/forums/Ma...Gr-t276540.html
just pm me if ur intersted
i use it in my 34 and i wont touch anything else at all anymore
https://www.sau.com.au/forums/topic/270784-oil/#findComment-4734386
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
