  • Replies 54
Yer i think we did........ MI GORENG noodles could possibly be the best food ever invented not only are they only 45cents a pack they taste fricken awesome could pretty much live on them........
" Do you want to go do karate in the garage"
funny how 2 minute noodles thread turns into step brothers quotes!!
mi goreng & 2min noodles = good shit!
step brothers = Great movie fkn hilarious!
You have the voice of an angel. Your voice is like a combination of Fergie and Jesus!!
i suprised you didnt have a heart attack.. mi goreng is very oily!! but damn good
hahaha all oily foods are damn good. But mi goreng well as you cansee i like them and you do know that the oil is an optional extra hahahahah judt like the chilli and the soy sauce.............
have you tried it without any of those??
im assuming it wouldnt be as good...it just wouldnt be mi goreng!!!
thris thread is gonna make me go buy a box!!! im hungry now..
Mi Goreng, $7 a box down at OK Oriental Mart in Joondalup.
I used to live off it, until I got a gf and now I spend like 100 a week on groceries :)
Yeah my gf always wants to go to the shops to get groceries for dinner, I still live at home and I pay board which covers my groceries and food at home.... I'm like "ffs woman there is stuff in the fridge/cupboard already :)"
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
