atm have greddy plenum, S15 inj, R34 turbo using RB20 act (they run 10psi std), nismo fuel pump & pressure reg......... have PFC, EBC, Z32 afm to go on soon as soon as i can work out if a decent cam upgrade is available with proven increase in power.
Car has been converted to Man trans too.
  • Like 1
https://www.sau.com.au/forums/topic/271077-s1-cam-upgrade/#findComment-4608750
yea, my bro and i bought a S2 half cut, he wanted the motor and wiring i wanted the conv kit. I changed bell housing too to R33 so i could use push type clutch rather the pull type. Only thing it didn't come with was handbreak and console which a mate who is an jap part importer over here in WA sourced for me brand new from nissan japan so she if 100% genuine. Am using S2 dash too so i dont have A/T lights and icon either. have all the console part numbers too if anyone requires them.
https://www.sau.com.au/forums/topic/271077-s1-cam-upgrade/#findComment-4608785
I just have (33 gtst cams) but can't compare because I changed other things as well. While we haven't had the cams degreed, my tuner and I reckon the stagea has milder cams than the 33 gtst - stageas always make less power on the dyno with the same mods.
https://www.sau.com.au/forums/topic/271077-s1-cam-upgrade/#findComment-4608875
haha no co-incidence here then, Mark is doing my stagea at the moment - hopefully you saw it there with no motor in :P
the stagea comes up a good 30kw lower than an equivalent gtst time after time. and standard gtst cams are worth basically nothing. I reckon someone with standard cams could test back to back with gtst ones even easier than getting a set measured up
https://www.sau.com.au/forums/topic/271077-s1-cam-upgrade/#findComment-4608960
wish i could say i did but im in WA so the phone is the closest i get to his workshop. Mark is great though really knows his stuff and is always happy to share his knowledge. I got my PFC back today so will be getting it tuned in a couple of weeks :P
https://www.sau.com.au/forums/topic/271077-s1-cam-upgrade/#findComment-4609139
what CAS is he using as mine is a S1 (R33 series motor) but runs a R34 series CAS (plastic cover) which has a different drive on it? also 33 use hydraulic and 34 use solid cams so which ever way i go i need to put 33 CAS on car.
Duncan did ou change to R33 CAS when ou put the GTST cams in it?
https://www.sau.com.au/forums/topic/271077-s1-cam-upgrade/#findComment-4609289
good question - its all going together now. I've got the 34 CAS too, so I think he will use the 34 head to save stuffing around rewiring the CAS.
Do all stageas run the 34 CAS, I thought it might be another "special" bit that the late S1 cars like mine got.
https://www.sau.com.au/forums/topic/271077-s1-cam-upgrade/#findComment-4609310
I run Tomei 256/256 poncams, with 8.8mm Tomei springs, and an adjustable cam gear pulley wheel.
Tomei have the poncams to suit depending on the year/month build of your engine.
Tune is happening right now, new GT30 bbiw turbo, p/up tomorrow morning well into the mid-200's I hope
https://www.sau.com.au/forums/topic/271077-s1-cam-upgrade/#findComment-4609341
Tangles, what year/month is your S1? do you still have the tomei p/n for your cams?
no worries
Im a Feb/1997 build
the Tomei poncams cam from Sliding Performance
Type A
Part #143050 Tomei Poncam Camshaft Set - Nissan Skyline R33 GTST Series 2 - RB25DET - Duration: IN/EX 256 Degree - Lift: IN/EX 8.5mm
$1219.oo from sliding performance
http://www.slidingperformance.com/store/in...mp;productid=23
Makes the engine feel like a 3litre, heaps of torque available before the turbo hits 0psi
https://www.sau.com.au/forums/topic/271077-s1-cam-upgrade/#findComment-4611101
yea metal CAS is R33 series, so to do cam upgrade on S1 with R33 series engine (non neo) with plastic R34 CAS you will need to change to R33 METAL CAS as drive on end of CAS is differnent, I have been told the wiring is different on them so you will need to speak to a mech or good tuner for more details.
PS nice cam cover Tangles
https://www.sau.com.au/forums/topic/271077-s1-cam-upgrade/#findComment-4611178
Brendan have you had the tune? What's the latest on the AWKW front? Please tell me its over 230 as i am hoping to acheive that without the port and polish and poncams!
https://www.sau.com.au/forums/topic/271077-s1-cam-upgrade/#findComment-4612133
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
